rough idling, code p1443
Old August 13th, 2006, 08:32 PM   #1
cyrax01 is on a distinguished road
Couple of plroblems, #1 code on cpu says that piston 2 is misfiring, already changed sparkplugs(oem), wires(MSD), And coils(msd), and also changed evaporative purge valve sensor(oem). Car still runs rough and weak. It used to clear up when I would rev the engine up for a little but now not even that will do it. Already pressure tested fuel system and it was fine. So could that mean that there is a problem with the fuel injectors? #2, Due to changing ignition parts, I would like to know what the spark plug gap calibration should be now. Any response will be greatfully apreciated. Car is a 98 gt 4.6, automatic due to wifes inabilty to drive manual . thanks in advanced!!
Old August 16th, 2006, 10:10 PM   #2
I am sorry if I am doing something wrong, like posting in the wrong spot or something, just that there has been no answer or any tips. If I did something wrong will someone please point me in the right direction. Thank You
Old August 16th, 2006, 11:45 PM   #3
00SoSlow's Avatar
00SoSlow is on a distinguished road
Send a message via AIM to 00SoSlow
im not that big of a tech guy, but maybe looking at ur IAC could help
2000 V6 Performance Red @ Cardomain Was fun but a waste...
1987 LX Hatch | Soon to be a 600hp monster
Old August 17th, 2006, 04:22 PM   #4
stang fanatic's Avatar
stang fanatic is on a distinguished road
ecc can detect misfire with restrictive fuel system or in your case possibly a dirty or misfiring injector...
"The gods too are fond of a joke."
"If I had only known, I would have been a locksmith. "
Old August 17th, 2006, 06:08 PM   #5
97Cobra's Avatar
1997 Mustang Cobra
1/8 - 8.89@86mph
97Cobra will become famous soon enough
I just fixed my code P1443 by replacing the EVAP purge valve and purge valve assembly. the code P1443 is just a EVAP system code. so it could be that you canister is cloged or you just need a new purge valve like I did. wich purge valves are more likly to go bad befor the canister. but hopfully its just the purge valve because it took me 10 minuts to replace both purge valve and assembly. if it is the canister you would have to remove your inner fender. so either way its pretty simple. but the others like rougf Idel and missfire I dont think P1443 has anything to do with it. because its just for emmisions. hope this helps......
Modifications and pics in my Garage...
Reps Appreciated!
Old August 22nd, 2006, 01:11 AM   #6
mark8796 is on a distinguished road
my gf's t-bird had same problem. upper intake manifold was cracked at heater hose fitting on passenger side/ rear of the manifold. coolant was leaking into the plug hole and fouling out spark. just a thought. good luck.
Old August 22nd, 2006, 10:44 PM   #7
thanks for the input guys, already changed the purge solenoid and valve and erased codes, now i just have to wait and see if the code p1443 comes back.
But now that mark mentioned about the intake manifold being cracked, I have been smelling the odor of antifreeze when it leaks on to something hot and just today i saw some mist comming from right around the area that he mentioned. Once again thanks for the input guys.
Threads Similar to: rough idling, code p1443
Sluggish and Pinging P1443 Code ? kevnsue 96-98 6 October 31st, 2007 08:53 PM
Code P1443 After using seafoam!??! 97redgt Modular Mustangs 3 September 28th, 2007 02:22 PM
P1443 97_4.6L_Stang 96-98 13 August 2nd, 2007 08:32 PM
Code P1443 Evaporative Emmision Control System Control Valve jagstang96 96-98 10 September 5th, 2006 07:26 PM
Code P1443 ? Please help 97Cobra 96-98 2 April 16th, 2006 05:47 PM
