#21 |
2005 Mustang GT
10.32@137.70
if the rings are bad oil would be on the tip of the spark plug that is sitting in the cylinder ( the part that jumps the spark ) , if you got oil on the socket and the top of the plug that the wire goes on then it is a valve cover leak
326 cubic inches of Turbocharged hell will be running soon Tuned by Wes @ TPS ![]() |
#22 |
just want to make sure...your positive about that?
1996 Mustang GT -MAC CAI -Polished 75mm TB and upper plentum -PI Intake Manifold -BBK underdrive pulleys -MAC Long Tube headers -Shorty H-pipe -Flowmaster Exhaust -18x9 275x35xR18 all around |
#23 |
Proud American
yea couldnt happen any other way. and even if you inspected the gasket they still can have small leaks. did you clean the oil off of the spark plug boot? is it back?
#24 |
MM's Coffee Addict
What I did was replace the valve cover gasket, clean the spark plugs clear of any oil residue (or just flat out replace them if need be), reinstall the plugs, and boots, run the car for awhile then see if there's any oil on the firing element (the "tip" if you will) of the spark plug... if there is, and you're certain you put the gasket on correctly, then you've probably got yourself a bad piston ring. If there's no sign of oil, then obviously it was the gasket and vuala problem solved.
![]() Vortech V2, intercooled @ 10psi. Maximum Motorsports supsension goodie bag car less roll cage. Built '04 IRS. Hodge-podge of Roush/Stalker panels. |
#25 |
awesome i appreciate everyone's input. It will be this weekend before i get a chance to fix it. i will let yall know what the deal is
thanks again
Threads Similar to: Oil with my spark plug!! HELP
| spark plug gap...wat does it need to b? | VSR13 | V6 Mustangs | 7 | January 30th, 2008 06:48 PM |
| spark plug gap | white93pony | 5.0 Mustangs | 8 | October 13th, 2007 11:51 AM |
| spark plug ?'s | tgk | 94-95 | 1 | August 25th, 2007 08:29 AM |
| Spark Plug Gap?? | smokiebear911 | 99-04 | 6 | July 19th, 2007 12:26 PM |
| Spark plug gap? | 8A_Honda | V6 Mustangs | 5 | July 6th, 2007 02:43 PM |
