Clutch still has a grinding sound?
Old November 4th, 2007, 04:35 PM   #1
adam585 is on a distinguished road
I just put in a new clutch and it still has a grinding sound, What would cause this. Also is there a time period that I should take it easy on the clutch?
Old November 4th, 2007, 06:46 PM   #2
97GT4.6's Avatar
97 GT
14.2@99.8 @ 4800 ft
97GT4.6 has a spectacular aura about97GT4.6 has a spectacular aura about97GT4.6 has a spectacular aura about
Send a message via AIM to 97GT4.6
Did you put in a new throw out bearing when you replaced the clutch?
Cammed 2v
Built By MustangMatt
More mods than times your daughter has slept around
Old November 7th, 2007, 02:45 PM   #3
yes
yes I did
Old November 7th, 2007, 03:39 PM   #4
suds488's Avatar
Est 13.9-14.5
suds488 is on a distinguished road
To my knowledge there is a break in period for new clutches. Just take it easy for awhile on it. Did you inspect the flywheel or change it?
96 GT AKA-Bethany 230rwhp 305rwt before head gasket leaked oil into 2 cylinders.
Rebuild in process....PI Heads P and P'd, Manley valves, Ported PI Intake, 75mm Plenum and TB, 24 Lb injectors, SCT dyno tuned, O/R xpipe, Merit Mufflers.
Old November 7th, 2007, 03:54 PM   #5
yes
I re surfaced the flywheel when we change the clutch.
Old November 7th, 2007, 04:14 PM   #6
Proud American
MustangMatt96GT's Avatar
Shouldnt be grinding how bout a new shift fork?
RIP Travis Billings
Special Thanks to:
Andrews Racing Transmissions
Baseline Suspensions
25.3 SFI Chassis Build
Never Lift Racecars
Old November 7th, 2007, 04:34 PM   #7
no
We looked at the fork and it look fine. Does anything else make a grinding sound other than the clutch? trany, belts?
Old November 8th, 2007, 01:22 PM   #8
Proud American
I say try changing out your cable, quadrant, and adjuster, and adjust it to see if the clutch just isnt disengaging and engaging completley!
RIP Travis Billings
Special Thanks to:
Never Lift Racecars
Threads Similar to: Clutch still has a grinding sound?
gear grinding Blk01ponyGT 99-04 22 September 19th, 2007 05:02 PM
t5 grinding in reverse tayboo24 5.0 Mustangs 19 June 4th, 2007 12:20 AM
Clutch Ticking Sound TheTechnical99 V6 Mustangs 11 November 12th, 2006 10:42 PM
Grinding Or Shaking Sound Bill 5.0 Mustangs 20 November 3rd, 2006 11:59 AM
Gear Grinding... jerb43 96-98 18 October 31st, 2006 07:19 PM
