pass side header stud/bolt
I was taking off my stock h pipe and I think I may have stripped the lower stud/bolt on the header where it connects to the mid pipe. I need to know if its a stud or bolt and if its a stud where could I buy a used header?
If it's too much I may just buy some shorties and say fuck it |
Anyone?
its a bolt, you might as well just buy some shortys while you at it.
#4 | |
So yeah I'm really debating now whether I am going to get some shorties because I will be coming up with some money soonly since I'm selling some stuff and getting money back for school
Well I've made up my mind then... what is the best way to install them? Also do you think I may damage anything if I just bolt up the X-pipe up to the headers and have the one bolt not secured? Just so i can go to someone's garage that is...
if you dont secure both bolts youll have a good exhaust leak, so both need to be tight. so i take it your getting some shorty headers right? the eaisiest way is to support the motor, unbolt the k member and lower the motor. it is a VERY tight sqweeze.
Proud American
just for a short drive to a shop it should be fine
Well I'm actually pretty sure if I can just get a thread going I may be able to put the old bolt back on... the thing is though I don't have something to re-thread the stud. I'm not sure I want to go thru the hassle of dropping the k member and lowering the motor since I don't have access to a lift of any kind or even a halfway decent jack for that matter.
any idea where I could get a tool to rethread it? ace maybe? |
Proud American
ace hardware sells dies that will rethread it. U will just need to know the thread. I work at ace
Well I can take in a bolt for the other side... so I should be able to do that... How big are they?
I'll probably just change my headers later on when I have access to a lift... or a cherry picker |
Proud American
yeah if you take the bolt there should be no problem! And they about the size of a half inch think quarter!
1997 Mustang GT
14.1140@99.36(need traction)
I stripped the stud and i just drilled it out and put a stainless steel bolt and nut on there.
1997 Mustang GT
I had one stud on the pass side for a while and no problems. Just make sure you have that gasket in there.
Fryrice has left the building. |
Oh I'm sure I have an exhaust leak now you can hear the ticking if I drive it lol.... I'm running over to a buddies shop sunday to get it out... heat up the stud and twist it out with a vice grip
#18 | |
Did you use a swivel joint and a breaker bar on it ? Along with some PB Blaster ? Yeah you can get that gasket from the dealer also.
Threads Similar to: pass side header stud/bolt
| Great...clunk in the rear pass. side | twok3gt | 99-04 | 2 | October 14th, 2007 04:53 PM |
| Well I stripped a stud! | MustangMatt96GT | 96-98 | 21 | September 20th, 2007 08:29 PM |
| header stud | mpboy | General Tech | 0 | August 28th, 2007 02:48 AM |
| striped header bolt | greenwood | Modular Mustangs | 4 | January 24th, 2007 10:37 PM |
| Wheel Stud Replacement | 2000v6 | V6 Mustangs | 5 | September 11th, 2006 11:42 PM |
