Caliper Rattle
My 94 Cobra has the factory installed front brake system. The problem that I am having is that the capliers rattle when driving down the road. If I replace the pins that hold the caliper in place, will/should this fix the problem? Is there anything else that i may need to replace? any advice is greatly appreciated. Thanks
Roy 1994 Mustang Cobra Drive it like you stole it!!! |
1988 Mustang LX Turbo
Sounds like someone has had them out and did a half ass job putting them back in
check all the bolts to see if they're there
1988 LX Coupe 2.5L, GT35R, 44mm WG, 32psi, C16. |
Id prob check'm all just in case. You shouldn't have to replace anything.
Big timin' in a small town
+1 someone didnt know what they were doing in this case. Stupid people strike again LOL
All of those thing sound feesible except for one problem, I do all of my own brake stuff. I have taken the pin out several times and verified that of the required hardware is firmly secured. I also double checked to verify that nothing was broken or visibly worn. The only thing I can see wrong is the slack at the pin that holds that caliper down. For the life of me I can not figure out how or why this is happening. I agree that there shouldn't be a valid reason other than something being loose. I know one thing, it is driving my up the wall!!
I had this problem on my 97 gt when i bought it. its the brake pads. take the wheel off and see if you can move the brake pads around pretty freely? if so look on the top of the caliper ( flat side facing the fender well) see that square hole? there is suppose to be a metal clip in there that holds the pads securely, buy a brake caliper parts kit, and it will come with a new one. let me know if thats the problem because i bet $100 it is
1986 Mustang GT t-top time piece! |
1997 Cobra
13.62@104
^ +1. they are called anti-rattle clips. mine never got replaced and they rattle like hell.
MM Cobra Club #29 Who are you?????? Choose your destiny!!!!!!
Threads Similar to: Caliper Rattle
| Caliper Seize | ScreaminYellow05 | V6 Mustangs | 2 | October 29th, 2007 04:43 PM |
| $3 caliper painting | texas_mustang | 2005 - 2010 | 33 | October 8th, 2007 10:47 PM |
| Caliper Paint | 01silversnake | 99-04 | 8 | September 12th, 2007 11:58 PM |
| caliper pistons | mikethetigerrr | V6 Mustangs | 6 | January 22nd, 2007 01:17 AM |
| Caliper Color | SlammedGT | Visual | 9 | October 7th, 2006 11:37 PM |
