Bullitt Intake?
Old November 12th, 2007, 10:46 PM   #1
suds488's Avatar
Est 13.9-14.5
suds488 is on a distinguished road
Bullitt Intake?
I just bought a bullitt intake to go on my PI heads for my 96 GT. I plan on putting a mild cam (stage 1) in the PI heads. I am also going to put a stroker rotating assembly in as well. What I want to know is should I put on an aftermarket throttle body or would the bullitt intake give me enought flow for my application. Or should I just have the the intake extrude hoaned to get more flow
Old November 12th, 2007, 11:30 PM   #2
Proud American
MustangMatt96GT's Avatar
Accufab TB if the funds permit
RIP Travis Billings
Special Thanks to:
Andrews Racing Transmissions
Baseline Suspensions
Never Lift Racecars
Old November 13th, 2007, 01:07 PM   #3
NMR-2vGT's Avatar
1996 GT
Too Slow....
NMR-2vGT will become famous soon enough
Send a message via AIM to NMR-2vGT Send a message via MSN to NMR-2vGT
I agree, I would go with either the 75mm or 70mm Accufab.
Old November 13th, 2007, 01:16 PM   #4
Proud American
Actually you cant get the accufab 75 for the bullitts. You buy the same thing as the cobra tb. I think its a 80 oval that you buy.
Port matching the intake to the heads will yield a little more up, but if you don't have the funds the bullitt intake its self will work really great.
RIP Travis Billings
Special Thanks to:
Never Lift Racecars
Old November 13th, 2007, 01:19 PM   #5
NMR-2vGT's Avatar
1996 GT
Too Slow....
Oh, didnt realize that.
Old November 13th, 2007, 01:24 PM   #6
Proud American
yea I may be wrong, but last I looked into a bullitt intake for my car I was going to get the cobra throttle body.
RIP Travis Billings
Special Thanks to:
Never Lift Racecars
Old November 13th, 2007, 02:02 PM   #7
ModMustang97GT's Avatar
1997 Mustang GT
Faster than an s4
ModMustang97GT has a spectacular aura aboutModMustang97GT has a spectacular aura aboutModMustang97GT has a spectacular aura about
I would be creful tho and see if you can fgind some flow numbers. It is possible to have too much TB and stall the air coming in to the intake. For instance, on a stock mustang with a Trickflow Plenum. The 75mm TB actually flows less than the 70mm TB. Now since you will be stroked and have new intake (I hope you have Headers and Heads to Compliment that), You will atleast be at the 75mm range but I don't know that you would be quite up to the 90mm flow that I believe the cobra's use. That is FI territory.
Old November 13th, 2007, 02:39 PM   #8
suds488's Avatar
Est 13.9-14.5
i was looking into buying a throttle body but it doesn't look like anyone makes them other than accufab. they are pretty pricey.I Just wanted to know with the set up I'm going to have should I fork out the money and by the TB when the stock flow around 1000cfm
Old November 13th, 2007, 02:57 PM   #9
Proud American
later down theroad you can. I saysave he money now, but eventually get one when u want more.
RIP Travis Billings
Special Thanks to:
Never Lift Racecars
Threads Similar to: Bullitt Intake?
Bullitt heads/intake on npi LXstang5.0 Modular Mustangs 4 October 18th, 2007 12:43 AM
Bullitt Intake Manifold neckbonekat 99-04 54 August 19th, 2007 11:03 AM
ppl with a bullitt intake DILO2001GT 99-04 4 July 17th, 2007 10:36 PM
