Discussing Temperature Reading High in the 96-98 Forum. ya i was driving home and i noticed that my tempature was on the high ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
2008 Black Bullitt
Sylv Rivial :P
ya i was driving home and i noticed that my tempature was on the high side like on the L on normal and useally its on the m or R
I think its the thermastat reading wrong or stuck. i think its the orignal any suggestions on whats wrong ??? |
All Throttle with a Bottle
its a gauge that is just a dummy gauge. Its not accurate at all!
![]() 1996 Mustang GT with a 351 swap with Stalled C4 1997 F250 Powerstroke 1999 28' Classic Dominator Special Thanks to: Andrews Racing Transmissions & Thanks for the help: PoorManMotorSports "Just Cause its Smoking, don't mean its broken" |
2008 Black Bullitt
Sylv Rivial :P
k
1996 mustang gt
mine did that too but it gradually rised little by little, days later and my t stat went out.
2008 Black Bullitt
Sylv Rivial :P
ya thats what mines doing
it looked like a while back when my fan belt went and the tempature went crazy and went all the way to red but its like hovering around the L and Red now but it wasn't doing it earlier today |
1996 mustang gt
why dont you check it, trow the t stat in boiling water to see if it opens up.
It could be a bad t stat. U could throw in a 180 when u pull it out anyway.
2008 Black Bullitt
Sylv Rivial :P
ya my dad going to taken it in tonight or tommrrow to have them do it cuase supposly he said u need a special wench or somthin to get it out
not just 2 8mm bolts holding it in place
2008 Black Bullitt
Sylv Rivial :P
ehhhh......
my parents took it to the shop today they called back later and they said it was the intake manifold 2 time replacing it last time was 8 years ago when my sister had the car |
2008 Black Bullitt
Sylv Rivial :P
now there putting on the series 3 on that the new mustangs have
anyone know if those are better cuase i know that they have aluminnum Crossovers |
the aluminum cross over is the repair for the plastic cross over. thats the one you want.
2008 Black Bullitt
Sylv Rivial :P
damn well i guess that wasn't the problem either
alright they changed the thermastat and they changed the intake mainifold and its still runin on the A and like I said before it useally runs between the R and the M even when i run it hard then it goes on the M anyone got any idea's on what is wrong they also changed the sending unit |
seems like a normal temp, I dont think it is overheating. I could be wrong.
2008 Black Bullitt
Sylv Rivial :P
thats what the guy said too but i always remembered it running on the between the R and M or alittle bit on the M
well mine runs right on the M or close to the right side of the M almost between M and the A
2008 Black Bullitt
Sylv Rivial :P
huh is that when u run it hard too?
i say just put in an aftermarket gauge.
Mine did that it turned out to be the thermostat, took it in and the guy replaced it and overtightened the polly intake bolts and cracked it the entire length on the passengers side. So out of it I got to do a PI swap and a 180* thermostat. Well worth it
I changed my heater core today and flushed my entire coolant system with a water hose. and now my temp gauge went from reading on the M to reading on the R
Threads Similar to: Temperature Reading High
| AutoMeter transmission temperature gauge | knightster420 | V6 Mustangs | 3 | August 17th, 2007 11:32 PM |
| Water Temperature | burnout5.0 | 94-95 | 5 | July 9th, 2007 06:07 PM |
| temperature gauge issue | 2004GT | Electronics | 2 | May 13th, 2007 09:54 PM |
| Temperature Gauge | lwhitetrash88l | V6 Mustangs | 4 | April 14th, 2007 11:06 PM |
| 1995 Mustang V6 temperature issues | I_CTCHR95 | V6 Mustangs | 1 | November 5th, 2006 10:43 AM |
