Tremec 3650 In 96 GT
Old November 17th, 2007, 04:10 AM   #1
jm06 is on a distinguished road
Send a message via MSN to jm06
i just bought a 2000 gt p.i. engine. the t-45 in my 96 GT is having problems, so i decided to swap to the tremec 3650 i got with the engine. i was hoping someone here had done the swap and could help me with a few questions. 1. is there a way to use my stock instrument cluster with that trans, with mine being analog and the 99+ being digital? 2. from what i can tell, the mounts are different.. any help? and 3. according to the tremec website, the 3650 is 3.5mm longer than the t-45. is that going to make much of a difference? i've tried google and so far no luck. any help would be appreciated. thanks.
Old November 17th, 2007, 12:55 PM   #2
Proud American
MustangMatt96GT's Avatar
you will have to get a new drive shaft. and personally, i wouldnt put in a 3650. It has just as many problems as a stock T45. I would put in a promotion powertrain built T45. You also probnably wont beable to use the stock cluster, because the VSS is completely different. That will also throw all your other gauges off. I say keep a T45.
RIP Travis Billings
Special Thanks to:
Andrews Racing Transmissions
Baseline Suspensions
Never Lift Racecars
Old November 18th, 2007, 01:06 PM   #3
invisa stang's Avatar
1992 mustang lx notch
invisa stang is on a distinguished road
Send a message via AIM to invisa stang
i say get a TKO b/c there way more reliable and can hold more power then any of tremecs other transmissions
Old November 18th, 2007, 01:21 PM   #4
StangAddiction is on a distinguished road
Send a message via Yahoo to StangAddiction
yeh 3650s are just as bad as t45s reliability-wise...But yeh i reccomend upgrading your t45....but you can upgrade to tko if funds permit..
Old November 18th, 2007, 02:46 PM   #5
i know the 3650 isn't much better than the t-45, but like i said, my t-45 is in bad condition. i would just get it rebuilt but i've already spent too much money on this swap. it IS still drivable tho, so if it comes down to it, i can put it back in the car. i'd just rather not. so basically i just need to know if it is possible to put the 3650 in my car, and if so, what mounts do you use? i haven't taken them off yet but they look different to me. thanks for the help!
Threads Similar to: Tremec 3650 In 96 GT
F**in tremec 3650 2002GTblkonblk 99-04 14 July 10th, 2007 11:41 AM
Tremec 3650 Fluid Garhfer 99-04 5 June 10th, 2007 01:55 PM
Putting a Tremec 3650 in a Fox 1990 Kevin b 5.0 Mustangs 6 June 5th, 2007 12:09 AM
Help with the Tremec TR 3650( PLEASE) H82LOSE 99-04 1 July 1st, 2006 06:16 PM
going with a 3650 instead of t-45 Q's JRuckas 99-04 4 September 9th, 2005 09:39 AM
