96 Mustang GT 5spd Vert.
Not sure need to go to a track
Npi Pi
hey guys i was just wondering what this PI and NPI crap is i know alot about cars but since i got my mustang i am rele gettin into the engine thanks guys
npi cars are the 96-98 gts and the 99-04 are pi. the pi motors have better head, cams, and intake that flow better than the restrictive npis. you can do a pi swap and gain some good hp. this raises you c/r from 9:3 to i believe 10:5.
![]() view my garage for pics and modifications listen to my exhaust video 1 video 2 video 3 Last edited by tlr96; November 17th, 2007 at 10:50 PM. |
thank you how much does a pi swap cost>?
The Hammer
Millenium Falcon
u can get it done for under a grand if u do the work urself and get used parts.
U can also keep ur compression the same if u only swap the intake and cams, like i did. U only gain +5 hp from the heads, the big jump is with the intake and cams. I did this even cheaper, about 600 in parts, and i changed things i didn't even need to change, just cause i was there. Being PI is the way to be with a 96-98, otherwise ur gonna have one hell of a time trying to break 300hp |
Proud American
with out a nitrous kit, or a blower you wont get a NPI car in the 300s.
The Hammer
Millenium Falcon
ur rights.........
as long as the npi manifold is on the car, it doesn't matter if u do head/cams annnnnd stroke the motor...... thats why PI is the way to be for us....even if u only go 2/3rd of the way |
Proud American
if i werent going to spray my car, i would be doing a heavily modififed NPI head, with aftermarket cams and the SVO intake. Or a full SVO set up.
arite thanks well im gonna look into it i definately want to hit 300 so thanks
what does pi n npi stand for
oh and if anyone could list what i would need that would b a great help (just intake n cams i want same compression) thanks guys
will this interfere with future mods?
P.I (performance improved) NPI (non PI). The npi heads are not as bad as some make them out to be, depending on what you want to do.
Cai Gears pulleys tuner S/C headers xpipe
#14 | |
X2 do a port job on the npi heads and and cams you can get a good amount of hp on a npi motor. but you can get more if you get a set of good hogged out pi heads with valves and springs.
4.6 2V PI HEADS,PI CAMS,COMP SPRINGS,PI INTAKE,03 COBRA CRANK,PISTONS,5140 S/F RODS, VORTECH S TRIM 6/9PSI 3.73 60 LBS INJECTORS,90 MM MAF, SCT CUSTOM TUNE. ![]()
![]() iTrader: -1 reviews
I've done this to my 97 and LOVE IT! Doing it to my brothers 98 now
