Exhaust Setup
Old November 21st, 2007, 10:51 PM   #1
zippeewannabee
ZoomZoomMFer's Avatar
06' Mazda Speed6
ZoomZoomMFer has a spectacular aura aboutZoomZoomMFer has a spectacular aura aboutZoomZoomMFer has a spectacular aura about
iTrader: 17 reviews
Send a message via AIM to ZoomZoomMFer
Exhaust Setup
hey guys i plan on going with this setup for an exhaust...
1. Hooker Longtubes
2. Hooker Catless H-pipe
3. Hooker Catback Exhaust
is there any thing else i need? or will that be the whole exhaust system..
Old November 21st, 2007, 11:00 PM   #2
JohnC's Avatar
1997 Mustang GT
13.56@102.94
JohnC will become famous soon enough
1) Use new stock Ford exhaust gaskets.
2) Use stage 8 locking header bolts
3) TQ every header bolt to spec
4) Tune with rear 02's turned off.
If those headers are so tight that you can't get to the bolts to TQ them, or can't use a stage 8 locking bolt, use the supplied bolts and loctite on the header bolts.
I know my BBK shorty header tubes went over some of the bolts, so I couldn't tq them all.
1997 Mustang GT
Aluminum Block PI swap & 4R70W to TR3550 swapped.
Best 1/8: 2.04 60ft 8.74@81.85 &
Best 1/4: 2.045 60ft 13.56@102.94
all on stock 245-17's
My Garage
Old November 21st, 2007, 11:02 PM   #3
JohnC's Avatar
1997 Mustang GT
13.56@102.94
Oh yeah, if you're doing this yourself, plan on dropping the K member. I've done 3 sets of headers on SN95 modular cars and the best way is dropping the K.
1997 Mustang GT
My Garage
Old November 21st, 2007, 11:19 PM   #4
supercharged421's Avatar
2004 Mustang
n/a
supercharged421 is on a distinguished road
Mac L/T headers
Old November 21st, 2007, 11:22 PM   #5
JohnC's Avatar
1997 Mustang GT
13.56@102.94
Originally Posted by supercharged421 View Post
Mac L/T headers
Yep, had those before and had room to TQ them all. If I ever build a new motor, new MAC LT's will go back on.
1997 Mustang GT
My Garage
Old November 21st, 2007, 11:29 PM   #6
2004 Mustang
n/a
ohhh yeah. the are BEASTT
Old November 21st, 2007, 11:43 PM   #7
zippeewannabee
06' Mazda Speed6
iTrader: 17 reviews
y do you say mac over hooker? doesnt hooker have a better rep
Old November 21st, 2007, 11:54 PM   #8
2004 Mustang
n/a
hooker has good rep
but i love the mac L/T headers
my advice is....
Mac L/T headers, go to an exhaust shop and have the headers put on and have them make you a true dual set up, custom H pipe, and flowmaster original 40's or mac mufflers
Old November 21st, 2007, 11:55 PM   #9
2004 Mustang
n/a
trust me.
you will love them
Old November 22nd, 2007, 12:08 AM   #10
1998 Mustang GT
Need to hit the track
RandoGT is on a distinguished road
or get some MAC LTs, Prochamber, and some SLPs or Magnapacks outback. yikes
Old November 22nd, 2007, 12:12 AM   #11
zippeewannabee
06' Mazda Speed6
iTrader: 17 reviews
cool thanks man
Old November 22nd, 2007, 02:27 PM   #12
JohnC's Avatar
1997 Mustang GT
13.56@102.94
Here is what I'm talking about when I say if you can get a TQ wrench on every bolt. And this is with the motor mounts off the block. If the mounts had been on, it would have been even worse.
BBK shorty headers on my PI motor:
1997 Mustang GT
My Garage
Old November 22nd, 2007, 03:24 PM   #13
Proud American
MustangMatt96GT's Avatar
I have hooker longtubes and ceramic coated with matching X pipe going on in the next month or so!
ANybody have detailed instructions how to drop the k member?
RIP Travis Billings
Special Thanks to:
Andrews Racing Transmissions
Baseline Suspensions
Never Lift Racecars
Old November 22nd, 2007, 03:48 PM   #14
97Cobra's Avatar
1997 Mustang Cobra
1/8 - 8.89@86mph
97Cobra will become famous soon enough
its not that hard... Ill find you a link real quick...
Modifications and pics in my Garage...
Reps Appreciated!
Old November 22nd, 2007, 04:26 PM   #15
JohnC's Avatar
1997 Mustang GT
13.56@102.94
What I can recall is...
Jack the car up with enough room under it to perform the work and support it on jack stands under rear axle and front frame rails just behind the K-member.
Unbolt the steering shaft. Mark the shaft when it slips/bolts together to make sure you get it right. Make 100% sure to re-torque to spec when you reinstall it.
Remove the front rims.
Remove the brake calipers and hang them with an old wire coat hanger. Don't let them hang by the brake lines.
Slide off the brake discs and set them aside.
Unbolt the shock from the 2 bolts at the bottom. It's easier to do unless you air tools to break the top nut loose.
Unbolt the steering rack and slide it off and unbolt the tie rods. Support the steering rack.
Unbolt the sway bar from the ends.
Unbolt the motor mounts.
Support the engine with a floor jack and use a block of wood between the engine and jack.
Use another jack to support the K member and unbolt the two bolts in each wheel well and the one on each side towards the floor board. Lower it down slowly and have a friend help balance it if needed. Keep an eye on the springs while lowering it as well.
Make sure to mark or scribe around the K member where it bolts to the car to make sure it’s reinstalled in proper alignment.
Installation is reverse of removal. Be sure to TQ everything back to spec per the service manual. If you don't have a TQ wrench, you can get one at sears for about $80-$100. I would get a 3/8 and a 1/2 drive TQ wrench.
Hope this helps and that I didn't forget something. It's been like two years since I dropped a K member.
1997 Mustang GT
My Garage
Old November 22nd, 2007, 04:31 PM   #16
Proud American
Yeah i have to buy 3 new torque wrenches! Owel!
Thanks sounds pretty simple. And i would do everything, except put in the new UPR instead of the old one back right?
RIP Travis Billings
Special Thanks to:
Never Lift Racecars
Old November 22nd, 2007, 04:54 PM   #17
JohnC's Avatar
1997 Mustang GT
13.56@102.94
If you have an after-market tube K member, I suggest using the plumb bob method to align the K properly. That is how the higher end manufactures suggest installing a new tube K.
Google it and there should be instructions for it.
1997 Mustang GT
My Garage
Old November 22nd, 2007, 05:08 PM   #18
97Cobra's Avatar
1997 Mustang Cobra
1/8 - 8.89@86mph
D&D Auto Detailing |
Reps Appreciated!
Old November 22nd, 2007, 05:13 PM   #19
97Cobra's Avatar
1997 Mustang Cobra
1/8 - 8.89@86mph
How-to: Install a tubular K-member [Archive] - BuckeyeStangs Message Forums
tubular k member install
Reps Appreciated!
Old November 22nd, 2007, 05:39 PM   #20
Proud American
Thanks guys! Sounds pretty easy!
RIP Travis Billings
Special Thanks to:
Never Lift Racecars
Threads Similar to: Exhaust Setup
Exhaust Setup For my V8?? tBuck345 General Tech 25 June 28th, 2007 11:19 PM
What's The Best Exhaust Setup? MustangMo V6 Mustangs 23 April 21st, 2007 04:20 PM
Exhaust Setup ?s Avaric3 V6 Mustangs 18 April 4th, 2007 11:41 PM
2 Stage Exhaust Setup? silktalon V6 Mustangs 5 November 16th, 2006 01:31 PM
Exhaust Setup BiGD12590 General Tech 15 September 14th, 2006 11:56 PM
