Car Wont Stay On!
i just went outside to go run a quick errand and i turn on my car, but it won't stay on! it will turn on, telling me there's nothing wrong with my battery or alternater, but it just kills itself. can anyone enlighten me on the subject?
Does it run properly otherwise? Like, if you drive it away, is it perfectly fine?
Also, how does it idle? Is it idling smoothly? Is it idling low? And how does it idle/run once it's warmed up? |
i tried driving it around, but once i take my foot off the gas it just dies. it doesn't want to idle at all.
And how does it run when you drive it, besides the idle problem? Running smoothly, or roughly...is it missing at all?
it'll drive fine until i let go of the gas. i let it "idle" in 1st gear and it stayed on but at extemely low rpms
All right. It sounds like your IAC or your TPS. (btw, I'm not sure what year your car is, but I'm fairly sure it has both of these sensors on your engine)
The IAC is your idle air control valve, and sometimes cleaning it will fix this issue. It may also just need adjusting. The TPS is your Throttle Position Sensor, and it can also cause this. Try adjusting or cleaning the IAC first. I'll see if I can search around on google to find out more for you. |
i appreciate the help. i'm gonna go try it out. and my car is a 98' GT (well...at least the one thats not working well) and a 94' GT
Proud American
iac or tps like zipster said.
okay good luck man. My first choice would be to test the iac.
#10 | |
Actually, I believe all EFI mustangs have both to the best of my knowledge...
Hey, EOD. I have some cool help here for ya.
First, go to this thread here in the forum, and follow the instructions for this free manual place: Clicky For Manuals Once you're there, find your way to your year and model of car. When you are at your proper manual, look for the 'EMISSIONS CONTROLS' section. Click that. When that expands, then look for the 'ELECTRONIC ENGINE CONTROLS' section. Click that. You will see in there all the different electronic sensors for your car, including the IAC & TPS, and how to remove and replace them.
#12 | |
thanks. i just took it off and i'm about to start cleaning it. i really appreciate the help. i'll let you know how it goes
Wow you work fast. lol Good stuff.
no luck with the iac and i don't have a multimeter so i cant check the TPS.
Magic, SA? lol
No luck meaning cleaning it didn't work, Eod? |
yeah. i cleaned it, but nothing.
Maybe the TPS is faulty, or maybe somthing threw the throttle body outta whack and its completely shut at idle (0 degrees straight)... i believe its supposed to be slightly open at idle... That would definately kill it.
i guess i'll see if my friend will let me take the TPS off his 98.
Threads Similar to: Car Wont Stay On!
| Got Her Running, But wont stay running...help? | Speedstang302 | 5.0 Mustangs | 10 | August 28th, 2011 05:58 PM |
| go new or stay old | usmc513 | 96-98 | 4 | October 30th, 2007 12:38 PM |
| wont stay charged | itsmyfiveoh | 5.0 Mustangs | 1 | June 22nd, 2007 03:26 AM |
| shop to stay away from | sonicblue | Shops | 0 | January 22nd, 2007 07:17 PM |
| Stang wont stay running, after warm up...???? | ttop5.0 | 5.0 Mustangs | 2 | November 28th, 2006 04:10 PM |
