Discussing Putting A PI Motor In My 98 in the 96-98 Forum. i was thinking i should just throw a low milege pi motor in my 98 ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
white 98 gt auto 02 pi motor sct tune o/r h pipe k&n intake tick flow plenum and bbk throtle body stedda udp eibach springs www.myspace.com/kirkb2 |
do it and then spray the crap out of it. you will run mid 12 on a good tune
4.6 2V PI HEADS,PI CAMS,COMP SPRINGS,PI INTAKE,03 COBRA CRANK,PISTONS,5140 S/F RODS, VORTECH S TRIM 6/9PSI 3.73 60 LBS INJECTORS,90 MM MAF, SCT CUSTOM TUNE. ![]()
1996 mustang GT/Mach 1
315rwhp 320rwtq
thats originally what i was going to do... the motor should run u about $1100 to $1500. but i decided to put a mach 1 motor in mine... found one for $2800 the PI motor install will cost around $1200, but the mach 1 will cost me $1900 everything should bolt up... but u may want to look at getting a new tranny since u have alot of miles on there if u plan on doing alot to the car...
ok so buy the motor and drop it in same ecu same tranny nothin has to be changed
#5 | |
2V NOT A 4V TO CHANGE TO A 4V YOU WILL NEED THE COMPUTER TO RUN IT!
96 Mustang GT 5spd Vert.
Not sure need to go to a track
u have 2v if its more u need new things
ok this just might happen in the near future
well u may not need a ecu seeing that if someone programs a sct chip for your car they can tell your old pcm what to do and whats in your car for motor, transmission the whole 9 if im not mistakin please correct me if i'm wrong
http://i23.photobucket.com/albums/b3...n1/dhacvpi.jpg 97 crown vic p71- P&P PI heads ,swap,Sct custom tune ,40 series flowmaster ,3.27's trak loc . |
That is correct, or he could go with a handheld programmer.
98k is NOT lot of miles on these cars when they are maintained properly. Regular maintenance etc.
Fryrice has left the building. |
#11 | |
+1, guys have had 300k+ miles on these motors without issues. why do people insist that 98k, 100k, 120k, etc is such high mileage. they are just barely breaking it in
Threads Similar to: Putting A PI Motor In My 98
| Putting An 03 GT In My 96 | JStang14 | 99-04 | 15 | November 19th, 2007 11:19 PM |
| Putting a 94 or 95 rear end in my 91 GT | ghoststang | 5.0 Mustangs | 3 | March 6th, 2007 01:16 PM |
| Putting In A V8? | jeff | V6 Mustangs | 6 | October 31st, 2006 12:54 AM |
| Putting 97 cobra motor in 97 gt. | bbrewer03 | 96-98 | 2 | August 24th, 2006 12:35 AM |
| Putting and 5.0 in my 94 3.8 | Easy04_jm | General Tech | 2 | April 24th, 2006 11:39 PM |
