Discussing Keyless Entry Remote in the 96-98 Forum. Does any one know how the hell to program another remote it says turn key ...
Old December 10th, 2007, 09:44 PM   #1
96GtGoodz's Avatar
96 Mustang GT 5spd Vert.
Not sure need to go to a track
Question
Does any one know how the hell to program another remote it says turn key to run or acc. then momentarily jump pins in the connector in the left rear QP
Deep Forest Green FTW!!!!
Spending all my money on it ^
Make sure to leave rep for helpful posts
Old December 10th, 2007, 11:31 PM   #2
96GtGoodz's Avatar
i dont believe no1 can help me lol cmon guys
Old December 10th, 2007, 11:48 PM   #3
All Throttle with a Bottle
MustangMatt96GT's Avatar
12.91@105.29 @ 5800 FT
yep its a long proceess let me look for it!
We expect shit to break, look foward to realizing exactly when it is happening, and than obsess about dropping plenty of cash to rebuild stronger, so we can try to run it hard as hell and break again. We are sick individuals.
Old December 10th, 2007, 11:59 PM   #4
Help me with keyless entry on my 97 GT.
Old December 11th, 2007, 12:08 AM   #5
97GT4.6's Avatar
97 GT
Burnouts get me bitches.
I never got keyless entry on my stang.. not sure how common they were in 97 lol
i didn't even get the original factory keys, and i don't have one that fits the trunk so i gotta open it from my glove box lol
1997 Ford Mustang GT|PI Intake|Spec 1 Clutch|BBK CAI|3:73's|SLP LM1 Resonators|O/R H Pipe|Mishimoto Radiator|Steeda Tri-ax |Cobra Hood|Bullitt Rims|Eibach lowering springs|1Inch H&R Spacers
Old December 11th, 2007, 12:12 AM   #6
Master of the Force
96GTRagTop's Avatar
Millenium Falcon
"Just Living the Dream"
the only key i got to my car barely would turn in the ignition, let alone the trunk. I bought my car from one dealership, then drove straight to ford to have them burn me 2 more cause the other was gonna snap
MSO smokes pole
Old December 11th, 2007, 12:19 AM   #7
96GtGoodz's Avatar
well i have the orig key n remote lol sry guys
Old December 11th, 2007, 12:19 AM   #8
96GtGoodz's Avatar
thanks matt
Old December 11th, 2007, 12:46 AM   #9
well its easy to see if it has keyless entry,
pull the trunk apart, and see if there is a black box in the drivers side rear fenderwell.
Old December 11th, 2007, 12:50 AM   #10
96GtGoodz's Avatar
oh yea i know there is lol i have a keyless entry but i need to program a second just incase well im bringin it to ford they are doing it i have not time or patience these next few weeks lol
Old December 11th, 2007, 11:13 AM   #11
Casper98GT's Avatar
You have PATS you cant program a second key by youreself. Some people have "said" they would trick the computer by using a magnet on the second key they wanna program but i have never gotten it to work. If you had 2 keys and wanted a third i could tell you how. But not if you only have one key.
White99stang-
Damn i miss the good ole days, you know in 2005 when the site first started and everyone wasn't getting butt hurt over every little thing
Ford/Toyota tech.
93 LX, H/C/I + Vortech
Old December 11th, 2007, 11:59 AM   #12
I have keyless entry on my 97 gt, but im not sure if it is stock because both the key and keyless entry pad say Strattec. What does yours say 96 GTGoodz?
Old December 11th, 2007, 03:09 PM   #13
96GtGoodz's Avatar
uhhh my key says ford lol and the remote says transmitter #1
Old December 11th, 2007, 03:12 PM   #14
Casper98GT's Avatar
strattec is what the dealership uses as a key they cut for you. So somewhere along the line someone had a new key cut. Thats all. Its still factory key. A dealership is the only place you can have one cut. So no matter what it says...thats where it came from.
White99stang-
Ford/Toyota tech.
Old December 11th, 2007, 03:24 PM   #15
96GtGoodz's Avatar
omg guys lol i know about that if its the orig or not i dont care about the key any way i was just askin how to program a second KEYLESS ENTRY REMOTE and i have no patience bringin it to the dealrship so they can program it
Old December 11th, 2007, 05:55 PM   #16
Casper98GT's Avatar
On a 1996 Mustang, here.
To program (or reprogram) keyless entry remote transmitter into the electronic door lock control processor (14B001), perform the following steps:
  1. Turn ignition switch to RUN or ACC position and momentarily short the two terminals of the Program Connector (two-pin connector next to the electronic door lock control processor. Remove LH luggage compartment trim panel to reach the connector). Both doors should lock and then unlock. Remove shorting pin.
  1. Press any button on keyless entry remote transmitter. All front doors should lock and then unlock to verify that keyless entry remote transmitter has been programmed.
  1. If door locks do not respond, press button again (up to three times maximum with the same keyless entry remote transmitter). If door locks still fail to respond, go to Pinpoint Test A.
  1. Repeat Step 2 to program additional keyless entry remote transmitters into the electronic door lock control processor (up to a maximum of four keyless entry remote transmitters).
  1. Turn ignition switch OFF. Both doors should lock and then unlock.
  1. Check operation.
Next time dont get so upset. I didnt understand what you meant i thought yo uwanted a second key.
White99stang-
Ford/Toyota tech.
Old December 11th, 2007, 06:02 PM   #17
97GT4.6's Avatar
97 GT
Alright thanks matt, ill have to check that out today.. im not sure if i want it or not, because if it does have it, it means that i don't have the fob or anything
Old December 11th, 2007, 11:55 PM   #18
Well i dont know, but my ace hardware can cut chipped keys for Fords and they work.
Old December 12th, 2007, 12:09 AM   #19
96GtGoodz's Avatar
now he is braggin about him and ace hardware lol y no more DFG?
just kddin
Old December 12th, 2007, 02:40 PM   #20
Casper98GT's Avatar
yeah in the door and trunk.
White99stang-
Ford/Toyota tech.
