Code P1443 Evaporative Emmision Control System Control Valve
this code keeps coming on if anyone knows what this valve looks like of where its located please reply and does this have anything to do with the idle of the vehicle
1999 Ford Mustang V6
...even fire and single cammin 1986 Ford F-150 5.0L 2WD 1994 Toyota Pickup 2.4L 4WD 1999 Ford Mustang 3.8L V6 2002 Jeep Grand Cherokee 4.0L 2WD 2008 GMC Sierra Denali 6.2L AWD |
99, thats a v6 ?
Anywhoo... youre code is for that EVAP purge solinoid. replace that and check the hoses. In that pic, its the thing near the intake manifold.
91 LX, 5spd. Ex:Toyota/Ford tech Marine Machinery Technician, Department of Defense.
yeah they don't have a picture of the gt, but it should look similar:
http://www.moddedmustangs.com/forums...ine-vt992.html
No, its ok. Youre picture got the job done.
purge solenoid
hey thanks for the help guys that did the trick what happened was the vac line was old and breacking apart and some debree got into the solenoid cleaned it out and put new vac lines did the trick thankss
No problem, i see it all the time.
idle
Hey casper are familiar with code 1506 idle overspeed error on a 96 gt non pi,, if u have whats the most common issue
hey man..... that code can mean alot actually.
Most times its the bad IAC.... can be cracked hoses, broken pcv hoses, carbon'd throttle body, kinked linkage, throttle body gaskets, air filters clogged, FRAM or other after market filters that allow air to leak by or to not get by, Youre evap system could be faulty..... So just check all the basics first. Make sure you have power and grounds to the IAc as well.
my car is running bad, I replaced my plugs, MAF, TPS, cleaned my IAC, new PCV, New o2 sensors, could my EVAP be bad? or what could it be? it idles bad, and shakes threw throttle response??
Coil packs ? alot of people replace MAF, plugs and wires and think it should be gone. They forget the coil packs. I just did them all at once with a kit. Great performance gains as well.
Not saying thats exactly youre problem... but its a far better answer then the EVAP thinking youre going with. Any CEL ?
Threads Similar to: Code P1443 Evaporative Emmision Control System Control Valve
| Traction Control System (TCS) and Anti-Lock Braking System | WAR-PARTY | 99-04 | 14 | May 1st, 2011 03:17 PM |
| Traction Control System (TCS) and Anti-Lock Braking System | WAR-PARTY | 99-04 | 11 | June 18th, 2007 08:56 PM |
| EVAPORATIVE EMMISIONS CONTROL FAULT??? | 97S281 | 96-98 | 7 | March 12th, 2007 02:54 PM |
| EGR Selinoid Control Circuite Code? | boliver | Modular Mustangs | 3 | November 22nd, 2006 11:25 AM |
| Purge Control Solenoid or Purge Control Valve fault | kdevildog01 | General Tech | 3 | July 17th, 2006 02:45 PM |
