Brake bracket.
Has anyone ever had a problem gettin the brake bracket back on after puttin in C Clip elim? any advice would be great.
Come on guys anything ?
48.47@ 12.58
front or rear brakes man
Rear. the brake bracket wont go on
48.47@ 12.58
did you turn the piston?
Not the caliper the bracket it wont fit on with the rotor.
48.47@ 12.58
which is why I am asking if you turned the pistons..
48.47@ 12.58
we may be misunderstanding each other here.
Ya... i havent even tried the caliper. i can't get the bracket to fit with the rotor because of the C Clips
It's like 1/2 and inch to flush the bracket wont fit between the rotor and the housing like i did.
Ok ive come to the conclusion that the c-clip elim must be pressed on to far. and thats why the axel is an 1 inch to close to the housing. anyone ever run into this or know a way to fix it ?
48.47@ 12.58
here ya go man..
read it Stock Fox Length Moser Axles, SN95 rear calipers, brackets, C Ciper Elim??? - Corral Forums
Thanks. i couldnt find anything anywhere.
Threads Similar to: Brake bracket.
| sway bar bracket | cali 5.0 | 5.0 Mustangs | 2 | November 18th, 2007 04:53 PM |
| PI alt. bracket? | caintcatchmyGT | 96-98 | 11 | September 7th, 2007 02:35 PM |
| C&L CAI - Mounting Bracket ? | black07cs | 2005 - 2010 | 3 | February 10th, 2007 06:07 PM |
| NEEDED bracket for 5.0, 302 | 85cj7 | 5.0 Mustangs | 1 | October 15th, 2006 10:27 PM |
| Alternator Bracket | acg | 96-98 | 2 | October 6th, 2006 08:38 PM |
