1997 mustang GT
Any tips?
Does anybody have tips on doing a Heater core on a 97 GT. I really dont want to spend another 700 dollars for installation on a 20 dollar part.
Proud American
You dont HAVE to evacuate the A/C system I didnt. Disconnect the battery and allow the car to sit for a couple minutes BEFORE you do anything else,otherwise your could set off your airbags.
I removed the dash and used a Dremel to cut the front half of the access panel off with a nice straight line. I used masking tape, a square and a marker to make the line and cut. I was able to pull the core out without touching any of the plumbing under the hood (except heater hoses obviously). Then I used the orange RTV to seal the panel back. That will save you a lot of time and money. I took the dash out by myself. Your gonna need to people to put it back. Make sure you wheels are line straigh and mark the relationship between t he steering shaft from the dash to the one coming outta the floor board. And dont let your steering wheel spin all over the place or else you can damage your clock spring.
Fryrice has left the building. Last edited by Fryrice; December 23rd, 2007 at 08:35 PM. |
not fun
Black 1998 GT- sub-fram connectors, shock tower brace, BBK intake, flowmaster catback, pro 5.0 shifter, king cobra clutch, perelli p zero neros. Hids, cleared headlights and fogs, mach 1 chin spoiler, K member brace, H&R springs |
Save the effort, and wear an extra coat and some gloves
![]() Cammed 2v Built By MustangMatt More mods than times your daughter has slept around |
BTW a heater core is gonna cost more than $20. OEM is around $100.
Fryrice has left the building. |
Proud American
95 i think
Yeah depending on the dealer.
I wouldn't skimp on this part.......you only wanna do it once.
Threads Similar to: Any tips?
| Tips for Men. | HMUSN | The Clubhouse | 42 | September 2nd, 2007 07:18 PM |
| tips | thetrooper31 | General Tech | 1 | June 13th, 2007 11:30 PM |
| New Here ... Need Some Tips For 01 GT | mst219 | 99-04 | 17 | October 23rd, 2006 04:22 AM |
| Looking For Tips On 99 V6 | Tmackin | V6 Mustangs | 31 | September 15th, 2006 03:58 PM |
