Will Lincoln Mark VIII block work on 1998 Cobra?
I have heard that other 4.6l 32v blocks will drop in to a 1998 Cobra Using Cobra heads and intake. If this is true, what blocks match up?
They're the same blocks with very few differences...Something with some side bolts i believe...read around...but yes...I see mark viii blocks used in cobras and GTs fairly often.
Proud American
they are the exact same block. all VIIIs from 93-98 had the Teskid block as did the 96-98 cobras.
Is there an issue with the difference from automatic MarkVIII to manual stang?
1998 GT
so is that an alum block? cuz thats what i need..... and if i can get that shit cheaper. hoahh damnit
Pretty sure a Teksid block is a Teksid block no matter what way you cut it. If the seller is smart they know what they have.
Yeah its alum block, but the internals are notoriously brittle, on the up side the heads flow better than the cobra ones with forced induction, so ive heard
![]() iTrader: 2 reviews
ive heard the heads on the mark have weak valve springs
2002 mustang v6- Auto, K&N CAI, Flowmaster dual exhaust, Black bullits dd 1996 mustang gt- 5spd, black, cobra hood, stock November Birthday Club Founder Old username: 97gt www.discounttiredirect.com |
'98 GT & '96 Civic
i thought the heads were the same?
#11 | |
96 GT
93-95 have weak valve springs Castings are the same as 96-98 Cobras,there is a little difference in valve-train.93-95 have weak valve springs, intake cams have 4 degrees less duration then Cobra ones,exhaust cams are the same. |
03 Cobra
![]() iTrader: 1 reviews
The FWD continental also uses a teksid this block absolutely will not work as the bellhousing design is totally different.
MM Cobra Club #86 2003 Mineral Grey Cobra 2004 True Blue F-150 FX4 |
03 Cobra
They are the same just need to swap you pilot bearing and clutch and flywheel assembly
1970 Mercury Cougar.
The block is the exact same aluminum teksid, the cobra stuff will bolt right up. The crankshaft, heads, and intake are different. The only truly weak valve springs were in 95, 96-98 have the best valve springs and the best heads. 97-98 has the best intake.
1970 Cougar. |
advice?
hey guys i see this dicussion i just got offered a 4.6 DOHC motor complete minus alt and intake form a 97 mark VIII for $450 with 114000 miles i wanna swap it into my 96 GT auto. good deal or no? i dont like the number of miles i was told to "freshen up" the motor by people in my car club if i bought it. wtf does that mean? talking about boring it out and going through it? anyways suggestions on this swap/buy would be greatly appreciated thanks guys.
Threads Similar to: Will Lincoln Mark VIII block work on 1998 Cobra?
| Lincoln Mark 7 | 93fourbangerstanger | 5.0 Mustangs | 4 | November 20th, 2007 05:59 PM |
| Mark Viii W/ P.I. Heads? | RALVAREZ26 | 96-98 | 0 | November 9th, 2007 08:10 PM |
| Difference between 98 cobra and Lincoln Mark VIII mod motor? | noyz25 | Modular Mustangs | 35 | October 18th, 2007 06:42 PM |
| Mark VIII computer in my 5.0? | 8A_Honda | 5.0 Mustangs | 0 | September 25th, 2007 09:44 PM |
