Coil Overs
Old December 24th, 2007, 11:35 AM   #1
Proud American
MustangMatt96GT's Avatar
Coil Overs
So, I have a question. I am going to be buying the UPR K member kit, and some Lakewood 90/10 drag struts. The kit comes with a coilover kit. So does that mean, I no longer need the front Eibach Drag Coil Springs? The coil over kit makes it so that the lakewood strut becomes the spring perch, and the coil spring now goes around the strut right?
RIP Travis Billings
Special Thanks to:
Andrews Racing Transmissions
Baseline Suspensions
25.3 SFI Chassis Build
Never Lift Racecars
Old December 24th, 2007, 11:46 AM   #2
TurboLX's Avatar
1988 Mustang LX Turbo
The springs for the front will have to go
the coil overs replace the stock struts
Old December 24th, 2007, 01:10 PM   #3
Proud American
but you have to have some strut in there right?
RIP Travis Billings
Special Thanks to:
Never Lift Racecars
Old December 24th, 2007, 03:05 PM   #4
¡ʇsnq ɹo uʍop ǝpısdn
Onemanzu's Avatar
from my understanding you should get all new components
Maximum Motorsports :: The Leader In Mustang Performance Suspension
if i were to get coil overs they would be the people i talk to... they are very knowledgeable and are a great help... best of luck with your plans dude
Old December 24th, 2007, 03:37 PM   #5
Proud American
Well, I dont have that much money!
And That is more of a handling set up.
Im going for the drag setup, and the whole front suspension will be new, A arms, everything. Except my CC plates I already have!
RIP Travis Billings
Special Thanks to:
Never Lift Racecars
Old December 24th, 2007, 03:38 PM   #6
TurboLX's Avatar
it comes with the new struts for the coil over to work with
Old December 24th, 2007, 03:41 PM   #7
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Yes, throw the drag springs in the garbage.
Old December 24th, 2007, 03:46 PM   #8
Proud American
Doesnt look like it comes with struts.
Unlimited Performance Racing Products On-Line - 1996 - 2004 Chrome-Moly K-Member Kit
and the lakewood struts I have been told can be used with coilovers or with out. So am i good to go?
RIP Travis Billings
Special Thanks to:
Never Lift Racecars
Old December 24th, 2007, 03:47 PM   #9
TurboLX's Avatar
thats strange
Old December 24th, 2007, 03:48 PM   #10
Proud American
It comes with the kit to make coilovers but not the actual struts.
RIP Travis Billings
Special Thanks to:
Never Lift Racecars
Old December 24th, 2007, 03:48 PM   #11
TurboLX's Avatar
i coulda sworn they came with the struts
im sure you can use the stock struts
Old December 24th, 2007, 03:56 PM   #12
Proud American
I dont want stock struts. I just replaced them and they are junk. I want some with good weight transfer.
RIP Travis Billings
Special Thanks to:
Never Lift Racecars
Old December 24th, 2007, 06:42 PM   #13
TurboLX's Avatar
then ill keep an eye for some good drag struts
im gonna be throwing my K member in soon so...
Old December 24th, 2007, 09:47 PM   #14
Proud American
I dont mind buying new ones, if that becomes the case. But let me know if you find something.
BTW whats the advantage of Coil overs?
RIP Travis Billings
Special Thanks to:
Never Lift Racecars
Old December 24th, 2007, 10:39 PM   #15
TurboLX's Avatar
The two big advantages to coil overs are that they weigh less and that they give you the same body roll control of a conventional spring that is twice as stiff. So, if you have coil-overs with 450lb springs, you'll get the same smoothness over rough roads as a conventional spring at 450lbs but you will be getting the same body roll control through the corners as an 800-900lb spring. Also, you can usually adjust the ride height with coilovers.
Coil-overs move the suspension point out towards the wheel from the stock location. This means the spring is much more effecient in helping to control wheel travel and body roll. You can run much higher spring rates and still have pretty good ride quality.
Because of their adjustability, the real advantage of coil-overs is in racing applications. You can change springs and suspension characteristics to match track conditions. You can adjust the corner weighting of the car to help turn in and exiting. You can adjust ride height.
For street use, unless you have money to burn, a good set of springs (lowering and/or stiffer spring rates in the stock location) and struts/shocks will serve you well.
Old December 24th, 2007, 11:31 PM   #16
Proud American
yeah, i think that it will work well with my drag/street car set up.
RIP Travis Billings
Special Thanks to:
Never Lift Racecars
Old December 24th, 2007, 11:32 PM   #17
TurboLX's Avatar
yep
Threads Similar to: Coil Overs
Coil overs singe General Tech 5 October 25th, 2007 01:04 PM
Good News/Coil overs creaking. J Mac0123 99-04 6 October 22nd, 2007 11:18 PM
Coil-overs, where? energiesource 99-04 37 August 29th, 2007 05:47 AM
Coil overs stanglover99 General Tech 2 July 16th, 2007 03:36 AM
2005-2007 Mustang GT 3V Coil Packs & Coil-on-Plug Connec ozan169 2005 - 2010 4 February 7th, 2007 09:03 PM
