1997 Mustang GT
14.1140@99.36(need traction)
problem
One of my Wheel studs that you screw the lugnut on stripped out, Are they hard to change out.
1997 Mustang GT Mac off-road H pipe, Magnaflow Magnapacks, Full Pi Swap, 3.73s, JLT ram air intake, Ram HDX clutch, MSD coils, MSD wires, Trickflow 75mm Throttle body, Trickflow intake plenum, MGW short shifter. |
Proud American
not really
front or rear? this is the write up i used when i put in my 3in studs. D&D Auto Detailing | It will be the same thing, but with shorter studs
take off your tire
then get a hammer and then hit the stud and then it should fall out threw the back slide in the new one put the lug nut on the stud and then tighten the lug nut and it will pull the stud into place. but i found this on google How to Replace a Damaged Lug Nut Stud | Expert Village Videos
Black 1998 GT- sub-fram connectors, shock tower brace, BBK intake, flowmaster catback, pro 5.0 shifter, king cobra clutch, perelli p zero neros. Hids, cleared headlights and fogs, mach 1 chin spoiler, K member brace, H&R springs |
Threads Similar to: problem
| umm have a weird problem? idle problem? | blue03mach1 | 99-04 | 16 | March 4th, 2008 12:03 PM |
| Got a problem what do you think? | MWWarlord | V6 Mustangs | 4 | October 15th, 2007 08:56 PM |
| big problem need help | 96gtponyred | 96-98 | 12 | August 22nd, 2007 01:36 AM |
| RIM Problem and Help | trueballerisme | 2005 - 2010 | 70 | August 21st, 2007 08:55 PM |
| I think i have a problem | Onemanzu | V6 Mustangs | 11 | August 16th, 2007 09:38 PM |
