Thermostat and Idler pulley
I'm getting new ones tommorrow to fix my beast..
What do I need to know about these tasks? And where is my thermostat located?
![]() Cammed 2v Built By MustangMatt More mods than times your daughter has slept around |
Proud American
thermostat is on the drivers side where the radator hose goes to the intake
there are two bolts and u pull it out, make sure the radiator is drained a little. Put in new thermostat and drop in the gasket. put all back to gether Idler pully Take off serpentine belt. Unbolt the bolts for the whole idler pully assembly. If you bought the whole assembly, replace it. If not take the acutal pully and replace that. And then put the assembly back on the car. Put the serpentine belt back on. Easiest if you pull up on the belt to get it on the altinator pully, not the idler pully.
Thanks matt, I appreciate it man
Threads Similar to: Thermostat and Idler pulley
| Idler Pulleys Underdrive pulleys? | 96GtGoodz | 96-98 | 4 | November 19th, 2007 11:02 AM |
| Thermostat? | burnout5.0 | 94-95 | 7 | November 9th, 2007 05:57 PM |
| Broke Idler Pulley - Twice!!! | gw604z2jnpps | 2005 - 2010 | 5 | October 8th, 2007 05:10 PM |
| Reverse Idler gear and countershaft gone | 02ponypackage | V6 Mustangs | 3 | March 28th, 2007 08:16 PM |
| thermostat | VSR13 | V6 Mustangs | 7 | February 22nd, 2007 04:46 PM |
