Discussing What springs should i get in the 96-98 Forum. what springs should i get. but in the futcher i would like to get 18 ...
Old December 28th, 2007, 12:29 AM   #1
what springs should i get. but in the futcher i would like to get 18 by 10 in the back and 18 by 7 or 8 in the front i don't want the tires to rub when i hit a bump.
Black 1998 GT- sub-fram connectors, shock tower brace, BBK intake, flowmaster catback, pro 5.0 shifter, king cobra clutch, perelli p zero neros. Hids, cleared headlights and fogs, mach 1 chin spoiler, K member brace, H&R springs
Old December 28th, 2007, 11:34 AM   #2
1997 Mustang GT
DO you want handling or Drag? Do you want cheap or expensive? Do you want new struts and shocks or not? Tell me these and I will tell you your spring. Or you can go to Stangsuspension.com. they have a great chart with the spring rates of our stock springs and just about every other spring out there, and wheather or not you will need new shock or struts.
Old December 28th, 2007, 12:26 PM   #3
Ryan Paymaster's Avatar
1996 Ford SVT Cobra
13.36@102
While we're talking about it, I have a 1996 Cobra with new lower / upper control arms, and Steeda Drag Springs. Setting the car up for all out drag eventually.
Should I be looking at replacing my shocks and struts also? I'm obviously going for drag, but would also sort of not like to pay the price of an adjustable strut.
Old December 30th, 2007, 01:24 AM   #4
i want handling
Old December 30th, 2007, 02:04 AM   #5
All Throttle with a Bottle
MustangMatt96GT's Avatar
12.91@105.29 @ 5800 FT
Just an Eibach Pro line kit.
We expect shit to break, look foward to realizing exactly when it is happening, and than obsess about dropping plenty of cash to rebuild stronger, so we can try to run it hard as hell and break again. We are sick individuals.
Old December 30th, 2007, 03:37 AM   #6
nes
or h&r ss...
laser red 98 gt- stock
Originally Posted by supermachone View Post
psh dude i slit throats all the time
Old December 31st, 2007, 01:33 PM   #7
is it true that the eibach's sag after 30 or 40 thousand miles
Old December 31st, 2007, 01:33 PM   #8
how about TEIN
Old December 31st, 2007, 01:36 PM   #9
do you have the HaRs how much do they drop the caR?
Old December 31st, 2007, 04:53 PM   #10
1997 Mustang GT
I have H&R Race springs. They drop the car between 1.5 to 2 inches in the front and 0 in the back due to Sag in the old springs . But it would be rougly 1.5" below stock. The H&R SS springs are very similar, but a little softer, bigger drop tho. Your looking at a 2 to 2.5" drop in the front and a 2" in the back. That is a very large drop. Your looking at a near no gap at all with 18''s and a very small one with 17" wheels.
For the Drag guy, its not going to make a HUGE change to change your shocks, although with any spring change, its a good idea to match your springs to your struts\shocks. You can get a good set of 5 way adjustable tokico illumina struts\shocks that will do Amazingly.
For the handling guy. Its up to you what you really want. I personally went the upper end route for springs and shocks, but not quite all out since I did not get Coil Overs. Coil overs are the cream of the crop, but since I alread had aftermarket sway bars (coil overs handle best with stock ones) and it was going to cost $500 more all together. I may convert down the road, but that is because I'm a nazi about body roll. I have H&R Race springs with Bilstein HD struts\shocks and Eibach Sway bars.
For companies on all of these things, there are a few things to remember. Eibach, Tokico, and Bilstein are all great companies. H&R is my personal favorite, but the Pro-line kit is good to. I have heard some questions about the quality on them, but alot of people swear by it, so I won't say its crap.
Old December 31st, 2007, 04:58 PM   #11
1997 Mustang GT
If you have any more questions, feel free to ask, I have researched suspension endlessly. So I have a decent knowledge base. I can tell you where I learned it all if you like.
Maximum Motorsports web site and e-mails with their techs
StangSuspension.com their articles and their forums
Griggs Racing.com (cool video of a 97 cobra that owns ferrari's)
And other assorted articles I have found.
Old January 1st, 2008, 11:14 PM   #12
ok thanks
Old January 2nd, 2008, 04:43 PM   #13
1997 Mustang GT
I forgot about Koni Yellow Shocks\Struts. These are pretty much the best Shocks you can get aside from the Valve adjusted Bilsteins from Maximum Motorsports. And those ones are necessary for a non Coil-Over car. They would be however, slightly overkill for anything less than a set of H&R race or possibly SS springs. You want to make sure your springs match the damper on the shocks.
Threads Similar to: What springs should i get
Ford c springs lowering springs itschristorres8 For Sale 7 July 10th, 2007 03:35 PM
4 Cyl Fox Springs On 96 GT... How Low? black04GT Suspension 0 December 14th, 2006 02:51 AM
C-Springs Mkenne4@tampabay.rr.com V6 Mustangs 3 December 9th, 2006 04:05 PM
Need springs! GTSilver 99-04 0 December 6th, 2006 02:22 PM
Are v8 front springs noticeably different vs. 4 cyl. springs 90hatch 5.0 Mustangs 3 August 8th, 2006 06:23 PM
