Discussing PI Cams! in the 96-98 Forum. that sux dude....... getting the cams in the heads is 10x harder when the heads ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
#21 |
1996 GT VERT PI at <3
Tell HMUSN he'll never catch me!!!
Location: "How does this thing work?"***BOOM***"Holy shit!!!, i just killed Zip!!!
getting the cams in the heads is 10x harder when the heads r on the block
Don't thank us, Rep Us |
#22 |
13.582@97.59 @ 5800 FT
it wont be too bad
![]() We expect shit to break, look foward to realizing exactly when it is happening, and than obsess about dropping plenty of cash to rebuild stronger, so we can try to run it hard as hell and break again. We are sick individuals.
#23 |
1996 Mustang GT Premium
15.2@91
so i'm confused... if i remove the heads and cams from one engine (in one piece) and put them in another, the ford tool doesn't do me a bit of good does it? don't i have to manually turn the crank so it's in safe mode, and then put the heads on and attach the chain when the cam timing mark is at the top?
ugh so confusing x.x |
#24 | |
#25 | ||
Swapping heads and cams from one car to another is very simple. Just put the motor youre swapping to top dea center and they will line up with the marks. Put youre motor to top dead center and then remove the bolt off the cam gear and remove. Then you can just swap them out and not touch anything. Everyone on this site has difference ways they "think" will work. So yeah youre right everything you hear is going to be very confusing. For you it will be a simple task and once you start ripping into the motor you have out of the car you will learn more about the one thats in the car.
White99stang-
93 LX, H/C/I + Vortech |
#26 | ||
White99stang-
#27 |
thanks casper. the guy i bought them from was real nice, and he did include the cam gear bolts. he was telling me about the tool to remove the hydraulic rockers. he told me i could buy one from napa. oh and i've been studying the sticky that you made all the time, so hopefully i wont screw up too badly. thanks again man
#28 |
You cant use those bolts, unless they are new in package. The bolts are TTY.
#29 | |
![]() Use lock tight on them and zap them in.
White99stang-
#30 |
where do i acquire some lock tight and are there any torque specs on the cam gear bolt?
#31 | |
If necessary, install Cam Positioning Tool Adapters 303-413 (T92P-6256-A) and Cam Positioning Tool 303-380 (T91P-6256-A) on flats of camshaft and install camshaft sprocket spacer (6265) and camshaft sprocket (6256) . Install bolt and washer and tighten to 110-130 Nm (82-95 lb-ft).
White99stang-
#32 | |
Since you have a NPI motor, use this 106 inch lbs
White99stang-
#33 | |
This is nice top have when and if you have to remove the front cover
White99stang-
#34 | |
valve cover pic, shows where to put sealant
White99stang-
Threads Similar to: PI Cams!
| Cams... | 96GTRagTop | 96-98 | 30 | November 16th, 2007 08:26 PM |
| cams | burin_rubber | V6 Mustangs | 13 | August 26th, 2007 02:41 PM |
| Anyone With CAMS??? | Regency 2007 | 2005+ | 6 | May 29th, 2007 06:07 PM |
| How many cams? | powersrj | Modular Mustangs | 10 | March 5th, 2007 05:24 PM |
| PI cams | 97_stang_gt | 96-98 | 4 | February 23rd, 2007 08:54 PM |
