1998 Mustang TSBs and Recalls - Forums at Modded Mustangs
post #1 of 9 Old October 8th, 2005, 07:02 PM Thread Starter
Casper98GT's Avatar
Field Service Actions (Recalls)
1998 Mustang
00S37
Safety Recall - Certain 1994 - 2001 Model Year Mustang Vehicles Equipped With Manual Transmission - Park Brake Control Assembly Modification
Published 10/2000
99S09
Safety Recall - Speed Control Cable Replacement
Published 03/1999
97S94
Safety Recall - EFFECTIVE IMMEDIATELY, A DEMONSTRATION AND DELIVERY HOLD is placed on certain 1998 Mustang vehicles equipped with 4.6L 2V Engines - for the installation of a new Fuel Rail Assembly.
Published 01/1998
Technical Service Bulletins
1998 MUSTANG
05-9-18
DISCHARGED BATTERY - CHARGING SERVICE TIPS
04-24-14
GENERAL PCM PROGRAMMING PROCEDURES
04-16-1
ENGINE MISFIRE OR ROUGH RUNNING - COIL ON PLUG (COP) IGNITION SYSTEMS - WDS COP KIT DIAGNOSTIC TIPS
03-23-2
BODY - MIRROR - EXTERIOR MIRROR GLASS AND MOTOR REPLACEMENT - SERVICE TIPS
03-20-3
DRIVEABILITY - MALFUNCTION INDICATOR LAMP (MIL) ILLUMINATED WITH DTC'S P0442, P0455, P0456, P0457, P1442 OR CHECK FUEL CAP LAMP ILLUMINATED WITH DTC P0457
03-18-1
ELECTRICAL - REMOTE KEYLESS ENTRY (RKE) - SERVICE TIPS
03-14-8
TRANSMISSION - NEW TRANSMISSION COOLER FLUSHER - SERVICE TIPS
02-22-1
DRIVEABILITY - SURGE/ROLLING IDLE - GEAR DRIVEN SYNCHRONIZERS - INCORRECT INSTALLATION - CAMSHAFT POSITION SYNCHRONIZER (CMP) INSTALLATION TOOL CORRECT APPLICATION
ENGINE - GEAR DRIVEN SYNCHRONIZERS - INCORRECT INSTALLATION - CAMSHAFT POSITION SYNCHRONIZER (CMP) INSTALLATION TOOL CORRECT APPLICATION
02-21-13
ENGINE - STRAIGHTEDGE PROCEDURE FOR CHECKING CYLINDER HEAD AND BLOCK FLATNESS
02-17-6
LAMP - BRAKE - INADVERTENT DISABLING OF BRAKE SHIFT INTERLOCK
02-16-4
FUEL SYSTEM - FUEL PUMP "WHINING"/"BUZZING" NOISE COMES THROUGH ENTERTAINMENT OR TWO-WAY RADIO SPEAKER
RADIO - ENTERTAINMENT OR TWO-WAY COMMUNICATION - "WHINING"/"BUZZING" NOISE IN SPEAKERS CAUSED BY FUEL PUMP
NOISE - "WHINING"/"BUZZING" - COMES THROUGH SPEAKERS OF ENTERTAINMENT OR TWO-WAY RADIO
02-11-4
ENGINE - NEW GASKET REMOVER/CLEANER AND SERVICE TIPS FOR ALUMINUM HEADS AND BLOCKS
02-2-2
COOLANT - COOLANT SEEPAGE AT INTAKE MANIFOLD CROSS-OVER - VEHICLES EQUIPPED WITH 4.6L 2V ENGINE ONLY
ENGINE - 4.6L 2V - COOLANT SEEPAGE AT INTAKE MANIFOLD CROSS-OVER
02-1-9
ENGINE - ENGINE OIL - RECOMMENDED APPLICATIONS FOR SAE 5W-20 AND SAE 5W-30 MOTOR OILS - GASOLINE AND FLEXIBLE FUEL VEHICLES ONLY
01-24-6
ENGINE - ENGINE OIL SYSTEM PRIMING PROCEDURES - SERVICE TIPS
01-23-6
ENGINE COOLANT - PROPYLENE GLYCOL - FORD MOTOR COMPANY POSITION ON ENGINE COOLANTS MADE FROM PROPYLENE GLYCOL
ENGINE COOLANT - PROPYLENE GLYCOL-BASED - FORD MOTOR COMPANY POSITION ON PROPYLENE GLYCOL-BASED ENGINE COOLANTS
01-23-5
TRANSMISSION - T-45 MANUAL TRANSMISSION - STUCK IN REVERSE - DIFFICULT TO SHIFT INTO REVERSE - POPS OUT OF REVERSE
01-21-13
DRIVEABILITY - DIAGNOSTIC TROUBLE CODES (DTC) P0500, P1502 AND/OR U1039 CONTINENTAL MODELS ONLY - STICKING OR BINDING IGNITION LOCK CYLINDER - HIGH EFFORT WHEN TURNING IGNITION SWITCH
ELECTRICAL - STICKING OR BINDING IGNITION LOCK CYLINDER - HIGH EFFORT WHEN TURNING IGNITION SWITCH
01-21-10
ENGINE - 4.6L - OIL LEAK FROM HEAD GASKET AREA - ROMEO BUILT ENGINES ONLY
01-15-6
CLIMATE CONTROL - REPEAT HEATER CORE FAILURE
COOLING SYSTEM - REPEAT HEATER CORE FAILURE
01-10-12
WIRING - WIRE HARNESS TERMINAL REPAIR KIT AND WIRE SPLICE PROCEDURE
01-9-7
DRIVEABILITY - HO2S (HEATED OXYGEN SENSOR), CATALYST, AND FUEL SYSTEM MONITORS - SERVICE TIPS - OBD II VEHICLES ONLY
01-6-2
PASSIVE ANTI THEFT SYSTEM (PATS) - DIAGNOSTIC SERVICE TIPS
00-23-10
TRANSMISSION - FLUID IN-LINE FILTER KIT - REPEAT REPAIRS OF TRANSMISSION - SERVICE TIPS
00-21-2
HOOD - HOOD REQUIRES EXCESSIVE EFFORT TO CLOSE - SERVICE TIPS
00-9-7
VIBRATION/SHAKE - AT STEADY SPEED APPROXIMATELY 100 KM/H (62 MPH) - VEHICLES WITH 4.6L ENGINE AND CONVERTIBLE TOP
00-9-1
LEAK - TRANSMISSION FLUID LEAKS AT RADIATOR - VEHICLES EQUIPPED WITH AUTOMATIC TRANSMISSION AND TRANSMISSION OIL COOLER IN RADIATOR END TANK
00-4-2
VIBRATION/SHAKE - AT STEADY SPEED APPROXIMATELY 100 KM/H (62 MPH) - VEHICLES WITH 3.8L ENGINE AND CONVERTIBLE TOP
99-26-9
FUEL ECONOMY - CUSTOMER EXPECTATIONS VERSUS VEHICLE USAGE
99-24-2
LOCKS - REPLACE AND/OR REPAIR ANY LOCK COMPONENT - AVAILABILITY OF INDIVIDUAL LOCKS
99-23-4
MALFUNCTION INDICATOR LAMP (MIL) - DIAGNOSTIC TROUBLE CODES (DTCS) P0442 AND P0455 - NO DRIVEABILITY CONCERNS
99-22-5
CONVERTIBLE TOP - IMPROPER FIT OF CONVERTIBLE TOP BOOT
99-20-7
COOLING SYSTEM - 3.8L - UNDETERMINED LOSS OF COOLANT
COOLING SYSTEM - 4.2L - UNDETERMINED LOSS OF COOLANT
ENGINE - 3.8L - ENGINE OIL CONTAMINATED WITH COOLANT
ENGINE - 4.2L - ENGINE OIL CONTAMINATED WITH COOLANT
99-18-5
TRANSMISSION CONTROL INDICATOR LAMP (TCIL) - TCIL ILLUMINATED WITH DIAGNOSTIC TROUBLE CODE (DTC) P0782 STORED IN MEMORY - VEHICLES BUILT BETWEEN 3/15/1997 AND 12/31/1998 AND WITH 4R70W TRANSMISSION
TRANSMISSION - 4R70W - DELAYED OR NO 2-3 UPSHIFT - VEHICLES BUILT BETWEEN 3/15/1997 AND 12/31/1998
99-11-1
NOISE - TSB SPECIAL FOR NOISE/VIBRATION/HARSHNESS
VIBRATION - TSB SPECIAL FOR NOISE/VIBRATION/HARSHNESS
99-10-1
BODY - DUST INTRUSION INTO LUGGAGE COMPARTMENT
WATER LEAK - EVIDENCE OF WATER LEAK INTO LUGGAGE COMPARTMENT
NOISE - EXCESSIVE ROAD NOISE HEARD FROM REAR WHEEL AREA
99-8-15
INTERIOR TRIM - DOOR TRIM PANEL REPLACEMENT - SERVICE TIP
99-5-3
TRANSMISSION - CHECKING TRANSMISSION FLUID LEVEL COLD - SERVICE TIP
99-4-3
REPROGRAMMING POWERTRAIN CONTROL MODULES (PCMS) - OUT-OF-VEHICLE - EEC V VEHICLES ONLY
99-2-3
WATER LEAKS - WINDSHIELD SEALING - SERVICE TIP
WINDSHIELD - SEALING - SERVICE TIP
98-26-2
FUEL - INFORMATION ON GASOLINE - TIPS TO RESOLVE VOLATILITY RELATED DRIVEABILITY CONCERNS
98-25-9
INTERIOR TRIM - REPAIRS TO VINYL COVERED SURFACES - SERVICE TIP
98-25-3
GLASS - FRONT WINDOW MAY TRAVEL BEYOND THE UPSTOP AND OUT OF THE GLASS RUN
98-24-6
ELECTRICAL - NEW TERMINAL GREASE RELEASED FOR SERVICE
98-23-12
TRANSMISSION - 4R44E - DIAGNOSTIC TROUBLE CODES (DTCS) P0705, P0708, P1704 AND/OR P1705 STORED IN MEMORY
TRANSMISSION - 4R55E - DIAGNOSTIC TROUBLE CODES (DTCS) P0705, P0708, P1704 AND/OR P1705 STORED IN MEMORY
TRANSMISSION - 4R70W - DIAGNOSTIC TROUBLE CODES (DTCS) P0705, P0708, P1704 AND/OR P1705 STORED IN MEMORY
TRANSMISSION - 5R55E - DIAGNOSTIC TROUBLE CODES (DTCS) P0705, P0708, P1704 AND/OR P1705 STORED IN MEMORY
TRANSMISSION - AX4N - DIAGNOSTIC TROUBLE CODES (DTCS) P0705, P0708, P1704 AND/OR P1705 STORED IN MEMORY
TRANSMISSION - AX4S - DIAGNOSTIC TROUBLE CODES (DTCS) P0705, P0708, P1704 AND/OR P1705 STORED IN MEMORY
TRANSMISSION - E4OD - DIAGNOSTIC TROUBLE CODES (DTCS) P0705, P0708, P1704 AND/OR P1705 STORED IN MEMORY
98-23-10
MASS AIR FLOW (MAF) - SENSOR CONTAMINATION - SERVICE TIP
98-22-2
CLUTCH - VIBRATION/NOISE FELT IN CLUTCH PEDAL WHEN LIGHTLY TOUCHING CLUTCH PEDAL
98-20-18
FRONT END ACCESSORY DRIVE (FEAD) BELT - BELT NOISE, DAMAGE, AND/OR BELT COMES OFF - VEHICLES WITH 4.6L ENGINE AND MANUAL TRANSMISSION
98-20-10
EXHAUST SYSTEM - LOOSE CATALYST OR MUFFLER HEAT SHIELDS
NOISE - "BUZZING" OR "RATTLING" - LOOSE CATALYST OR MUFFLER HEAT SHIELDS
98-20-3
BODY - ADHESIVES NOT RECOMMENDED FOR BODY PANEL REPAIRS - SERVICE TIP
98-18-2
PAINT - EXTERIOR - WORLDWIDE RECOMMENDED PAINT MATERIALS FOR WARRANTY AND AFTER WARRANTY REPAIRS
98-17-18
MOULDINGS - ROCKER PANEL - LOOSE
98-12-5
AIR CONDITIONING - FILTERING REFRIGERANT AFTER A/C COMPRESSOR REPLACEMENT - SERVICE TIPS
98-9-9
FUEL INJECTORS - NON-WARRANTY REIMBURSEMENT TESTING INFORMATION
98-7-4
LEAKS - OIL - AVAILABILITY OF NEW SILICONE GASKET AND SEALANT
98-5A-5
BRAKES - AVAILABILITY OF HUB-MOUNT BRAKE ROTOR MACHINING EQUIPMENT
BRAKE ROTOR MACHINING - AVAILABILITY OF HUB-MOUNT BRAKE ROTOR MACHINING EQUIPMENT
98-5-2
TIRE - TIRE COMPANY TELEPHONE NUMBERS FOR CUSTOMER ASSISTANCE
98-4-12
TRANSMISSION - 4R70W - SERVICE PROCEDURE FOR ORANGE SERVICE TAGGED TRANSMISSIONS
98-4-4
PAINT - ANTI-CHIP STONE ABRASION UNDERCOAT - SERVICE TIP
97-25A-1
EVAPORATIVE EMISSIONS SUPPLEMENT
97-24-13
REMOTE KEYLESS ENTRY (RKE) - DIAGNOSTIC SERVICE TIPS
97-21-10
TRANSMISSION - 4R70W - NEW DESIGN ENHANCEMENTS FOR 1998 VEHICLES
TRANSMISSION - 4R70W - NEW ONE-WAY CLUTCH (OWC) TO SERVICE AT THE INTERMEDIATE POSITION
97-19-11
COOLING SYSTEM - "ON-VEHICLE" HEATER CORE PRESSURE TEST REQUIRED FOR WARRANTY CLAIM
97-15-5
AIR CONDITIONING - OIL REFILL CAPACITY CHART - SERVICE TIP
1995 SVT Mustang Cobra. Stock...
2006 Mitsu Evo MR full bolt on with FP Green 500awhp
1992 LX 69k miles, ON3 70mm single turbo
2009 Toyota Camry SE DD
Ex:Toyota/Ford tech
Casper98GT is offline
post #2 of 9 Old October 8th, 2007, 12:46 AM
5.0pwr's Avatar
Did you find this information on Alldata? We use it in the auto program im currently in, and its pretty amazing.. and there's a helluva lot of Technical Service Bullitens..
5.0pwr is offline
post #3 of 9 Old October 8th, 2007, 12:51 AM Thread Starter
Casper98GT's Avatar
No i did not. I got it from the Ford technicians website
Ex:Toyota/Ford tech
post #4 of 9 Old October 8th, 2007, 12:55 AM
Ryan Paymaster's Avatar
How would I go about finding out any TSB / Recalls on a 1996 Cobra? Obviously, they don't do me any good now, but it could help diagnosis at a later date in the future. Thanks!
Also, thanks for this, very informative.
Ryan Paymaster is offline
post #5 of 9 Old October 8th, 2007, 03:11 PM
Is there any way to know if my car had any of these updates as I have only owned it for a year?
1998 Mustang GT Convertible, black on black on black with MAC prochamber H, Flowmasters, PI intake, SCT tune, K&N.
militant54 is offline
post #6 of 9 Old October 8th, 2007, 07:57 PM
that long list is only for 98's correct
red 97 mustang GT
red97 is offline
post #7 of 9 Old October 8th, 2007, 08:26 PM
ujslost's Avatar
Thanks Casper.
militan it is possible to find out by having an Oasis ran on your car. That will tell you most everything. Maybe Casper would run an oasis for you if you asked him to.
ujslost is offline
post #8 of 9 Old October 8th, 2007, 10:00 PM
What's an oasis? Is that like a run on the VIN, like a detailed carfax type report?
post #9 of 9 Old October 8th, 2007, 10:04 PM
ujslost's Avatar
Its a report from ford about, services performed at the dealership, and tells what you car came with from the factory.
ujslost is offline
Human Verification
