Discussing Code P0411? in the 96-98 Forum. has anyone fixed this code and what was it ,secondary air inj is not enougn ...
Old September 15th, 2006, 07:53 PM   #1
Code P0411?
has anyone fixed this code and what was it ,secondary air inj is not enougn info for me and what symptoms did this code come with,and where is this air inj and what does it do?
Old September 25th, 2006, 08:25 AM   #2
this code is set when the pcm comands the pump on durring self test and it looks for the 02's to go lean with the extra air pumped in by the pump. If it doesn't see the change, the code is set. It can be caused by the pump or controller, or a problem with the 02 sensors.
take care, John
Old September 25th, 2006, 11:32 AM   #3
replace the pump. more than likely it's dead from water intrusion. Remove the pump from the pass side fender area underneath and hotwire it to a battery. betcha it doesn't run.
88 Mustang Coupe
www.rickscarcare.net
http://img146.imageshack.us/img146/2158/ricksadql2.jpg
Old September 26th, 2006, 01:01 AM   #4
99mustang232's Avatar
1999 Ford Mustang V6
mine died a long time ago from the same thing, here is what it looks like... i just deleted mine, you will still throw a code or two but can get the CEL turned off with a custom tune. i think ford wanted like 180 for replacement pump when mine went
...even fire and single cammin
Old September 26th, 2006, 08:26 AM   #5
Thats it alright. It usually injests water and locks up and usually takes out the electronic relay/controller as well. Both pieces end up setting U back about 300-400$ + labor and diagnosis.
Old September 26th, 2006, 07:52 PM   #6
I guess I will take my otc diagnostic moniter as a copilot for awhile to reset the mil. does the mil affect performance in any way?
Old September 26th, 2006, 10:19 PM   #7
It should not hurt performance. Air being pumped into the exhaust is to help the convertors to be more efficient. Just remember that someone down the road will have to pay the price for not trying to keep the air clean. I have nothing against improving performance, but please keep the emissions as clean as possible.
take care, John C
Old September 26th, 2006, 11:51 PM   #8
it pumps air into your exhaust manifolds 0-120 seconds after startup to help burn up left over hydrocarbons, sometimes at idle it will activate too. this is also called the california emission's package or secondary air ijection. one of the bearings also went in my pump causing a loud tapping noise too, rather annoying... you would think with as many people that had them go bad ford would of recalled them or issued a tsb?
Threads Similar to: Code P0411?
need help with a code 1quickstang02 99-04 4 October 9th, 2007 09:08 PM
Code 84?? How do I fix?? MonsterSD 5.0 Mustangs 2 August 5th, 2007 01:08 PM
Code Help MnrlGry01gt 99-04 8 July 24th, 2007 08:52 PM
96 GT vs 64 D-code 289 MustangMatt96GT Modular Mustangs 4 January 11th, 2007 06:34 PM
Code 66 cali 5.0 5.0 Mustangs 3 November 9th, 2006 01:40 PM
