Discussing 3,000K + 96' GT Moter in the 96-98 Forum. Hey guys. What can I do with about $3,000.00 to get the most ...
Old January 25th, 2008, 06:36 PM   #1
MM's Most Laid Back
Lefty's Avatar
01' Cobra Vert. & 96' GT
Hey guys. What can I do with about $3,000.00 to get the most amount of horsepower from my 96' stock GT Motor. Or how much horsepower can I get from the stock motor safely with $3,000.00?
Old January 25th, 2008, 06:39 PM   #2
nes
there is a used vortech on ebay right now, buy it now is 2k, that could easily put u over 300rwhp with a tune, so consider the money spent.
laser red 98 gt- stock
Originally Posted by supermachone View Post
psh dude i slit throats all the time
Old January 25th, 2008, 08:12 PM   #3
96GtGoodz's Avatar
96 Mustang GT 5spd Vert.
Not sure need to go to a track
lol def not over 300 get a p.i. swap tuner gears exhaust what is in your car now?
Deep Forest Green FTW!!!!
Spending all my money on it ^
Make sure to leave rep for helpful posts
Old January 25th, 2008, 09:32 PM   #4
nes
simply adding a tuned vortech and a pi intake will yeild him 300+rwhp. and the one on ebay comes with a tuner, just no tune...
Old January 25th, 2008, 09:33 PM   #5
nes
and i guarantee if he can do the installs on his own he could do it for less then 3k
Old January 25th, 2008, 11:46 PM   #6
hey man i have a 96 gt i just junked that engine went to the junk yard and for $500 got a 2000 gt engine which are the best engines from 96 to 04 because they used the windsor block. i forged the bottom end out did some bolt ons and cams and all together i made 310 rwhp and 336 rwtq for around 3800.00. do yourself a favor and loose those heads and put a set of pi heads on non pi heads are junk and your just throwing your money away if you dont swap them with the same cams and bolt ons before the engine swap i only made 262 rwhp.
Old January 26th, 2008, 12:11 AM   #7
All Throttle with a Bottle
MustangMatt96GT's Avatar
12.91@105.29 @ 5800 FT
Windsor vs Romeo block have no differences in the amount it can handle. They are nearly identical with different size bolt holes.
We expect shit to break, look foward to realizing exactly when it is happening, and than obsess about dropping plenty of cash to rebuild stronger, so we can try to run it hard as hell and break again. We are sick individuals.
I support the MM Staff
Old January 26th, 2008, 12:16 AM   #8
1998 Mustang GT
Need to hit the track
owned by the yetti...
anyway, i say pick up a blower for as cheap as possible, some boost with the PI swap, and that should put you well past 300RWHP. if you're looking for more then get your bottom end forged, put some lower compression pistons in there, port the heads, put a big cam in there, and do the rest of the bolt ons and what not....that'll be way past 3000 though.
option 2 is a route that i was gonna take and Matt is taking. PI swap for the compression raise, better parts, NOS cams or custom cams, throw in a shot of nitrous and then go from there. your car, your choice
Old January 26th, 2008, 12:40 AM   #9
NMR-2vGT's Avatar
1996 GT
Too Slow....
as everyone else said....
Option one-find a used blower and put it on there or
Option two- do the PI swap with PI heads, some cams(maybe stage 2 comp cams or something) and the PI intake and then nitrous. And with whatever you have left over do gears and maybe some suspension if you have extra money
1996 Mustang GT, Full PI Swap, MGW Shifter, Magnaflow Cat-back, K&N Filter
Former name: Lethal2v
Old January 26th, 2008, 01:05 AM   #10
nes
eBay Motors: Mustang Vortech Supercharger 99-04 4.6 L (item 170187979949 end time Jan-29-08 12:22:11 PST)
did all the searching for you, now buy it.
Old January 26th, 2008, 01:07 AM   #11
nes
and learn to spell motor
