Discussing 3 angle valve job? in the 96-98 Forum. I am going to be doing the PI swap shortly just waiting on uncle sam!!! ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
98 Mustang GT
13.6 @ 102
3 angle valve job?
![]() i have a set of 5.4 heads from a lightning with cams...my question is is it worth it to get a 3 angle valve job done on them i can get it done for $150 if so what are the gains from doing this...... |
98 Mustang GT
13.6 @ 102
anyone ? lol
1998 Mustang GT
Need to hit the track
get a valve job and get them ported while you're at it. i wouldn't know too much about that kind of stuff. PM Boomer if he's still around here. he'll know a lot more
98 Mustang GT
13.6 @ 102
cool thanx!!
1998 Mustang GT
you dont really want an "angle" more of a radius on it. an angle would decrease flow. but id look at a 5 point if your gettin anything done. i
98 GT summer toy. 05 FORD explorer Daily Driver. See Garage For Mods. the wheels of his mustang exploding on the highway like a slug from a 45. TRUE DEATH. 400hp of maximum performance piercing the night. this is black sunshine. |
1998 GT
Many Seconds
Would the 5 point be similar to "tulliping" the valves? I built a 3.5 liter alluminum V8 for a small british sports car project a while back. We did some minor porting, an agressive cam, milled a fair amount off for a bump in compression, and a 3 angle valve job. Also ran double valve springs. The machinist talked about going a step further and "tulliping" the valves, which sounds similar to what a 5 point might have been. This would have been a lot more money, and since the car weighed roughly 2100 lbs, we were fine with hp in the 250-275 range.
Dunno if any of this rambling helps....... |
1998 Mustang GT
yea its more of a racing thing. not a neccessery(sp?) thing,but if your going for max na power,it helps. its a little more work on the seat,adding different layerd cuts making the inside more "rounded" apose to triangular with a 3 angle. you wont feel any difference but it may flow .5-5% better depending on how deep you go,and the skills of your machinist. would probably cost maybe 20-30$ more depending on the shop. imo money well spent.
tuliping is bad lol,thats when the seat is starting to flare out kinda like )( where a normal seat would be / \ and the valve face begins rolling into the cylinder,kinda closing it up lik a tulip. i
3 angle valve jobs on the the street are a waste of time and money...
1998 Mustang GT
ure crazy
![]() It's Never Enuff |
1998 Mustang GT
If your not getting your heads done then yes it wouldnt make any sense to have it done. If your heads are being built then its more than worth it. But i would definatly move to a bigger set of valves.
A 3 angle is worthless imo unless your doing an import.
98 Mustang GT
13.6 @ 102
Thanx for all the input guys!!!
Threads Similar to: 3 angle valve job?
| pinion angle | notchabovechevy | 5.0 Mustangs | 10 | January 25th, 2008 12:36 AM |
| Control Arms and Pinion angle | gsjohnson | 99-04 | 2 | November 30th, 2007 10:22 PM |
| upper control arms (pinion angle) | bigmike83 | Suspension | 4 | February 8th, 2007 07:55 PM |
| upper control arms (pinion angle) | bigmike83 | 96-98 | 2 | January 3rd, 2007 01:58 AM |
| Pinion Angle? | sn-95aac | 5.0 Mustangs | 1 | November 2nd, 2006 04:10 PM |
