Coolant leak and HVAC Problems
Every damn day, there's something else broken on this car. Today, I was driving to school, had my defrost on to clear the windshield, and I turned it to vent after it was clear. Well, the switch turned but its still on the Defrost. All settings it stays on defrost except for the off setting. It did this once before, but fixed it self. Any ideas?
Also, I just drove it home, and noticed a puddle of coolant, looked under the hood, and it appears to becoming out of the side of the radiator. What do you recommend i can put in there to stop the leak? I'd prefer not to have to put in a new radiator. Thanks
![]() Cammed 2v Built By MustangMatt More mods than times your daughter has slept around |
99 Cobra
13.77 @ 102
![]() iTrader: 1 reviews
I recommend a new radiator to stop the leak!
![]() Might be a bad A/C mode selector switch????? I think that may be vacuum operated. It might be a bad vacuum diaphragm????
99 Cobra, T-56, Spec Stage 3, aluminum driveshaft, MGW shifter, shorties, X, FM Amer. Thunder, 3.73, SRA, JLT CAI, Tokico struts, adjustable UCA's/LCA's, H&R Rear Springs |
KB'd GT
I think defrost is the default if there is no vacuum signal. I would look for vacuum leaks. Mythbusters stopped a radiator leak by cracking an egg into it.
JK, haha, I would look for a radiator patch kit, JB weld it, or buy a bigger better radiator. |
oh, do you think it could be related to these?
KB'd GT
Alright thanks, ill be sure to get em fixed. My auto teacher and former ford tech said they don't make em anymore, so i have to find some hose that fits over, does anyone know if its possible to get replacements?
Threads Similar to: Coolant leak and HVAC Problems
| Slow Coolant Leak | Ugmul | 99-04 | 3 | February 4th, 2008 11:09 AM |
| coolant problems | dag545 | 5.0 Mustangs | 7 | January 30th, 2008 12:25 PM |
| coolant leak? | shadow98gt | 96-98 | 3 | May 14th, 2007 02:59 PM |
| Coolant leak? | shan | 96-98 | 12 | April 26th, 2007 08:52 AM |
| Coolant Leak Help | garyvang | 5.0 Mustangs | 13 | May 11th, 2006 10:55 PM |
