Engine Oil Question
ok so i changed my oil filter n put in new engine oil awhile back.....i kno it aint time fora new oil filter but i think i need to add more oil or should i jus drain the old one n add all new ??? I just went out to check it, n well i stick it in, wait a couple secs, pull it out n the damn stick comes out dry...so should i jus add more oil or drain it n put new ????? and since i dont have time now id like to opt jus addin more oil in, would that be a problem ??? all opinions would be appreciated, also i forgot what we use, is it 5 or 10-30 ?
BAD ASS BOYS DRIVE BAD ASS FORDS!!! |
i would go ahead and change it all and then check it again. you don't want to just keep addin oil cuz #1 it could get kinda costly and 2 you never wanna over fill and engine,you'll start blowin' seals.
Nobody gonna take my car Im gonna race it to the ground Nobody gonna beat my car Its gonna break the speed of sound Oooh its a killing machine Its got everything Like a driving power big fat tires And everything - Deep Purple |
#3 | |
yeah just to be on the safe side that way you got a fresh start. thats what i'd do cuz i don't think you want to be replacing the motor unexpectedly.
I am bad cop
2003 F150 XLT FX4
it's a truck
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 0 reviews
yea and also if it comes out dry dont drive it till you get it filled because you could be a couple of quarts low or completley dry and i wouldnt risk finding out the hard way been there done that old truck blown motor to prove it lol
When you checked the oil,was the car cold or hot ? You should check it cold,to get an accurate reading. And always keep your oil change and filter change on the same schedule.
I would drain it all,then add 5 quarts.After you fill it,run if for a few minutes,and shut it off and let it cool completely,then check the level.You also wanna use 5w-30 .The factory usually uses 5w-20 on some models,but thats just for better fuel economy to meet federal standards. Does your car have over 75,000 miles ? Then you need a high mileage oil that will help protect seals and older moving parts. Get a 5w-30 high mileage oil. Also,if you engine is real dirty,clean it off real good,so that way after you run it again,you can tell if you are lossing any oil around gaskets etc.
Fryrice has left the building. |
Threads Similar to: Engine Oil Question
| engine question | energiesource | 99-04 | 6 | August 14th, 2007 01:29 PM |
| engine question | hopper | 5.0 Mustangs | 2 | June 21st, 2007 10:01 PM |
| engine question | Drixops | V6 Mustangs | 10 | February 8th, 2007 08:50 PM |
| First Engine Mod Question... | DSEZ | V6 Mustangs | 19 | January 24th, 2007 09:14 PM |
| Engine Question | man_of_war2081 | 99-04 | 19 | November 16th, 2006 06:56 AM |
