hot alt wire - Forums at Modded Mustangs
post #1 of 11 Old January 1st, 2017, 11:56 AM Thread Starter
philly101's Avatar
hot alt wire
so the main wire that gose to the alt to the fuse box to the batt got so hot it burned off the top of alt boot what could be goin on here
philly101 is offline
post #2 of 11 Old January 6th, 2017, 10:53 AM
Are you running any aux lights, amps, etc?
Harris79 is offline
post #3 of 11 Old January 7th, 2017, 09:45 PM
Check all fuses, inside and out first. Then look for any loose wires to fix or tape up with electrical tape. Finally, check all grounds.
Malcolm83 is offline
post #4 of 11 Old January 8th, 2017, 09:24 PM
04MCcobra's Avatar
I'd try looking for any bare wires. Maybe some of the insulation came off and a wire is touching bare metal
04MCcobra is offline
post #5 of 11 Old January 8th, 2017, 10:30 PM Thread Starter
philly101's Avatar
check all the fuses i do have a 1500w amp hooked up i think i found the probl i see the ground wire that i think should go to the eng an the frame its red on the drivers side its just on the frame hanging
Just a few moddes 2 in drop ksport an MAC cat back pi intake an siting on 17x11
post #6 of 11 Old January 8th, 2017, 11:02 PM
The wire is red? That means its a HOT/Power wire usually, so if it is grounding out to the chassis it is shorting and that is why things got so hot. Any major electrical issues/noticeable electrical issues at all prior to?
2003 Redfire & Black V6. Full suspension, 8.8 w/ 4.10s, tuned. 4.3L built for turbo + turbo capable of 550 hp on the way
DD: 2015 SHO PP, CAI, Axlebacks, Tune,blacked out/AMR wheels. 12.87 @107 1/4 mile (1.8 60')
Derfdog15 is offline
post #7 of 11 Old January 10th, 2017, 11:28 AM Thread Starter
philly101's Avatar
no none at all but what it looks like is a fuse able link an some one put red over the wire I will take a pic soon
post #8 of 11 Old January 10th, 2017, 11:49 AM
Gotcha. A burnt useable link is generally indicative of there being another issue, as it burns up, and opens the circuit, in order to protect other components.
If the wire was added by a previous owner/someone else, it may indicate that this is an issue that has been ongoing.
post #9 of 11 Old January 10th, 2017, 01:23 PM Thread Starter
philly101's Avatar
its not brunt or any thing like that its just not on could this be the prob
post #10 of 11 Old January 10th, 2017, 08:35 PM
Gotcha, in that case I would recommend finding out where it should be connected and reconnecting. May or may not fix the issue but I am optimistic that it will.
post #11 of 11 Old February 8th, 2017, 04:46 PM
John D
MustangJohn89's Avatar
Check the alt cable with a volt meter while its running and see if the alternator is overcharging
-The little two valve that could-
MustangJohn89 is offline
Human Verification
