3.73 Gears -Top Speed - Forums at Modded Mustangs
post #1 of 26 Old March 23rd, 2008, 11:54 AM Thread Starter
So, sorry if this has come up recently, or is a common question, but I'm in need of an answer here...
I have a '96 GT, and I'm changing the gears and I'm pretty sure I want 3.73's. I know what they do, how they work, and how to install them. I'm wondering by how much do (you think) they lower your top speed? Just say its a stock 'Stang. Is the top speed noticebly lower? Is there a way to figure it out exactly (formula)?
Thanks.
sixty8fastback is offline
post #2 of 26 Old March 23rd, 2008, 11:57 AM
HMUSN's Avatar
iTrader: 11 reviews
you don't have enough power to ever reach your top speed.
areo dynamics will stop that.
welcome to the forums
Howstuffworks "How Gear Ratios Work"
HMUSN is offline
post #3 of 26 Old March 23rd, 2008, 01:30 PM
68 dlxcoupe's Avatar
Send a message via AIM to 68 dlxcoupe
I've been 155 with my 3:73's
http://www.moonshine-media.net/68dlx2.jpg
EAGLE SCOUTS OR GTFO
MyStangOpens (12:01:05 AM): honey nut for me
68 dlxcoupe is offline
post #4 of 26 Old March 24th, 2008, 12:51 AM Thread Starter
155 is pretty impressive haha. Thanks.
post #5 of 26 Old March 24th, 2008, 01:39 AM
IBEATU
stanglifemike's Avatar
Welcome to the forums
98 GT: some stuff
06 GT: more stuff
93 Notch: 4 cyl at birth, now 5.0 drivetrain and stock exterior and interior= True Sleeper
Paxton/Vortech Crew Member #3
FRPP's #1 Dealer
Injected Engineering
BMR Suspension
stanglifemike is offline
post #6 of 26 Old March 24th, 2008, 01:43 AM
97GT4.6's Avatar
iTrader: 5 reviews
Send a message via AIM to 97GT4.6
I'm not sure, ive gotten up to about what my speedo says is 138 which is about 128 with my gears.
97GT4.6 is offline
post #7 of 26 Old March 24th, 2008, 02:01 AM
Droptop Snake's Avatar
aerodynamics will stop that.
I hear ya. I've got a .50:1 6th gear. I should look up what my theoretical top speed is with 3.73s.
Droptop Snake is offline
post #8 of 26 Old March 24th, 2008, 02:10 AM
dc1515's Avatar
yea im a bit confused as well.. i have heard if you get new gears your top speed gets all f$*%'d up.. is this true? if i get 4.10s will i be slowed down at higher speeds?
[SIGPIC][/SIGPIC]
Flowmaster
MAC Prochamber
PI swap
JLT CAI
BBK 70mm T/B
Coming Soon --- Ford Racing 4.10s, SCT XCAL3
dc1515 is offline
post #9 of 26 Old March 24th, 2008, 02:52 AM
97GT4.6's Avatar
iTrader: 5 reviews
no you won't be slowed down at higher speeds, but you top speed is reduced because you are turning more RPMS
97GT4.6 is offline
post #10 of 26 Old March 24th, 2008, 02:53 AM
97GT4.6's Avatar
iTrader: 5 reviews
and like HMUSN said, aerodynamics come into play hardcore at high speeds. you should worry about having more power, and lots of open road with no cops versus redlining it in 5th
97GT4.6 is offline
post #11 of 26 Old March 26th, 2008, 09:58 PM
I've pinned my speedo past 150 with stock gears and wasn't near redline. With my 3:73s I've only been 140, but getting closer to redline. It still has enough gear left to go up to 150 with 3:73s, for sure.
sean 96 gt is offline
post #12 of 26 Old March 26th, 2008, 10:00 PM
HMUSN's Avatar
iTrader: 11 reviews
there is enough gear with 4:10's too.
HMUSN is offline
post #13 of 26 Old March 26th, 2008, 11:53 PM
Ryan Paymaster's Avatar
I'm going to say if you are worried about top speed with any gear ratio you better be running the 9's in the 1/4 mile.
You are never ever going to hit top speed in a reasonable or safe amount of time. I don't even think Terminators are worried about it.
Plus, when are you ever going to peg 155? That's for single digit cars.
Ryan Paymaster is offline
post #14 of 26 Old March 29th, 2008, 12:32 AM
Found a free program online that does the calculating for you once you've entered tire size and gear ratios. It's called GearCalc. Looks to have been made in the UK, but has options for metric and imperial measurements.
Theoretical top speed for my Viper-spec T56 and 3.73s:
Gear --- Mph per 1000 RPM --- Mph @7000 RPM
1 --------- 7.69 -----------------54
2 --------11.50 ------------------80
3 --------15.74 -----------------110
4 --------20.47 -----------------143
5 --------27.66 -----------------194
6 --------40.93 -----------------287
Guess I'd better follow some ricers to the Tacky Aluminum Wing store.
post #15 of 26 Old April 1st, 2008, 10:59 PM
Yea, 3:73s aren't going to hurt your limit you unless you want to go 165+ for some reason. Your speedo only goes to 150 anyways. I've gone 140 with my 3:73s and was about 5000 rpm or so I think.
98GT - BBK CAI, BBK T/B, BBK Plenum, Steeda Pulleys, BBK o/r X, SLP Loudmouth, 3:73 Gears, Diablo Tune, Steeda Tri-Ax, H&R Super Sports (Eibach Springs in sig), Tokico Shocks
post #16 of 26 Old April 1st, 2008, 11:04 PM
RavensChild's Avatar
120 for me lol. It took about 2 miles to get there or more lol
HARDCORE CREW
dude, be the first person in history to sue somebody for not letting you polish your dolphin while looking at porn.. you'll become a legend
RavensChild is offline
post #17 of 26 Old April 3rd, 2008, 06:19 PM
BLUE OVAL NUT's Avatar
The gears should help you pull harder on top-end, my old 96', 5-spd barely made it too 135 mph.
BLUE OVAL NUT is offline
post #18 of 26 Old April 3rd, 2008, 08:14 PM
Send a message via AIM to kennyGT
welcome to MM curtis how long you been browsing hear lol?
07 GT/CS manual - STOCK
88 LX automatic-SOLD
01 GT manual-UNDER CONSTRUCTION
97 GT automatic-SOLD
kennyGT is offline
post #19 of 26 Old April 4th, 2008, 07:21 AM
BizCutt's Avatar
It also depends on tire size, horsepower, etc. I was running 373's with a pretty much stock 4 valve...in 4th gear i would top out 140ish with a 26" tire...went like 13.20@ 106...i put the 410's on the same car topped out around 130ish but went..12:80@ 109...put the blower on the car and with the 26" tire was topping out @ around 120-125 in 4th..put a 28" tire on the same car topped out around 135....
i like this calculator myself it works pretty darn close each time for me
HI-PERFORMANCE CALCULATORS
97TT Gobra For Sale 697rwhp 662rwtq
no one to play with but the dyno
BizCutt is offline
post #20 of 26 Old April 4th, 2008, 02:03 PM
^those are some big tires
HARDCORE CREW
Human Verification
