Piston Stop
I'm using the Comp Cams Degreeing Kit for my GT and they aren't any help at all.....they told me i was doing something wrong. Well my piston stop is too small for the hole.....what do I do??? And when i get it in there, how far do i adjust it???
![]() EAGLE SCOUTS OR GTFO MyStangOpens (12:01:05 AM): honey nut for me |
Proud American
What im going to do is rotate the crank until I have TDC of #1 with out the heads on. Im going to mark it. Then do the same thing for #5 so i dont have to deal with that things. its confusing to me.
............dammit. i cant pull the heads off cuz i dont have another 250 for headbolts and gaskets
Proud American
lol somebody else will tell you how im sure.
We'll lets see, if I just set the piston stop in there and adjust it to the proper setting, I can rotate the crank and I have a friend watch when the stop moves. I guess itll work the same way??
OK now where do I adjust it
I made a piston stop,,,take the center out of a used spark plug ..take a peice of all tread stick it threw spark plug hole .use nut on each end .you need about 1 in sticking threw..
?? Do you have a picture of it?
Threads Similar to: Piston Stop
| Can't Get The Leak To Stop... Stop Me From Doing This. | militant54 | 94-95 | 21 | February 27th, 2008 10:17 AM |
| Piston heads | imported_Gt_Jay | 5.0 Mustangs | 23 | January 22nd, 2008 12:01 AM |
| 347? about rod & piston combo | And then some | 5.0 Mustangs | 14 | October 5th, 2007 11:54 AM |
| Piston Question | bigbadtalontsi | 5.0 Mustangs | 5 | January 18th, 2007 12:20 PM |
| PISTON ? | 89GTCONV | 5.0 Mustangs | 1 | June 14th, 2006 10:44 PM |
