Shortie Header install
Old April 15th, 2008, 12:09 AM   #1
96GtGoodz's Avatar
96 Mustang GT 5spd Vert.
Not sure need to go to a track
96GtGoodz is on a distinguished road
does anyone have a write up of their header install i am gettin FRRP shortie headers MAC O/R X and they guy is giving me MAC pro dump(not using)
Deep Forest Green FTW!!!!
Spending all my money on it ^
Make sure to leave rep for helpful posts
Old April 15th, 2008, 12:13 AM   #2
Proud American
MustangMatt96GT's Avatar
drop the k member and take all the steering with it.
Makes a hell of a lot of room. Let me go grab pictures.
RIP Travis Billings
Special Thanks to:
Andrews Racing Transmissions
Baseline Suspensions
Never Lift Racecars
Old April 15th, 2008, 12:27 AM   #3
Proud American
RIP Travis Billings
Special Thanks to:
Never Lift Racecars
Old April 15th, 2008, 12:36 AM   #4
96GtGoodz's Avatar
hmmmmm
can i do it without dropping anything out this is gonna be a ghetto in driveway install i wanna pop out the stockers pop in the FRRP's will there be any difference between stock and FRRP shorties?
then i know the mid pipe is easy
Old April 15th, 2008, 12:41 AM   #5
Proud American
headers are a PITA. I would personally take the heads off and put the headers on and then put the shorties in place. It would be worth it to me. I would never put a shorty header on though. LT all the way. And i took my K member out, and will beable to bolt the header on to the head and put the head in place.
RIP Travis Billings
Special Thanks to:
Never Lift Racecars
Old April 15th, 2008, 12:43 AM   #6
96GtGoodz's Avatar
should i bother with the FRRP Shorties and keep the stock headers
or should i throw the Shorties on?
Old April 15th, 2008, 12:56 AM   #7
Proud American
I wouldnt. I would put Longtubes on there, but my car will never get emission tested either.
its up to you. I doubt you feel any power gain.
RIP Travis Billings
Special Thanks to:
Never Lift Racecars
Old April 15th, 2008, 12:57 AM   #8
96GtGoodz's Avatar
yea i dont have any money for longtubes though i just care about the O/R X i know that will give me 5-10 and alot of noise
Old April 15th, 2008, 12:58 AM   #9
JStang14's Avatar
JStang14 is on a distinguished road
dont take the heads off, itll cost you another 100 bucks to put them back on, the bolts are not reusable
Old April 15th, 2008, 01:00 AM   #10
Proud American
agreed. head bolts are a 100 bucks, but worth it imo. Just use ARP stuff the time you put it on. Or just buy PI heads and do the swap then.
RIP Travis Billings
Special Thanks to:
Never Lift Racecars
Old April 15th, 2008, 01:01 AM   #11
JStang14's Avatar
if you were going to do it i would get arp studs, then you can take them off as much as you want, but they're a little over 200
Old April 15th, 2008, 01:07 AM   #12
Proud American
yea im doing ARP studs i paid 209.99. Shorties just arent worth it IMO
RIP Travis Billings
Special Thanks to:
Never Lift Racecars
Old April 15th, 2008, 01:11 AM   #13
96GtGoodz's Avatar
well this mid pipe is meant for shorties or stock so if i were to get longtubes i would have to get another mid pipe i guess just put the mid pipe in and when i can get longtubes and new mid. i will
Old April 15th, 2008, 04:01 AM   #14
JStang14's Avatar
the shorties will help a little, i'm not a huge fan of the frpp because they look like a better manifold but either way there will be a gain just not as noticeable as lt's but if you have the shorties you should put them in
Old April 15th, 2008, 12:25 PM   #15
96GtGoodz's Avatar
ok thanks man
Old April 15th, 2008, 02:07 PM   #16
96GtGoodz's Avatar
ok well i have a buddy comin by with tools jacks stands etc... so gonna throw it all on the pro dumps O/R X and Shorties
Old April 15th, 2008, 04:53 PM   #17
Rollin' 18/ pushin' 2
97S281's Avatar
1997 Saleen S281
97S281 is a name known to all97S281 is a name known to all97S281 is a name known to all97S281 is a name known to all97S281 is a name known to all97S281 is a name known to all
iTrader: 13 reviews
You'll need to remove the starter to get access to the stock manifold on the right side.(Theres 3 bolts, not 2.). You'll have to undo the steering shaft on the left side. Make sure your steering wheel is locked before you do this. You will also need to remove the bottom end of the egr tube from your stock manifold. The manual suggests removing your dipstick as well, but I didn't find it necessary. I just cut the new gasket in half on that side and slipped it past. Using some tack on the gasket and putting it in place on the head will save you alot of frustration. Have fun getting to those damn bolts!!!!!!!!!!!!!!!
MODS IN GARAGE
NCMM ORIGINAL
BLOWN 96-98 CREW MEMBER # 1
Old April 15th, 2008, 04:56 PM   #18
97S281's Avatar
1997 Saleen S281
iTrader: 13 reviews
You will also find it very helpful to transfer the studs from your existing right side manifold to your new right side header before installing it. You may as well tack welding the nuts onto your new left side header before installing it, otherwise you'll have a hell of a time tightening it to your midpipe.
MODS IN GARAGE
NCMM ORIGINAL
Old April 15th, 2008, 04:57 PM   #19
97S281's Avatar
1997 Saleen S281
iTrader: 13 reviews
you may also want to have a tiny oriental man or a small child available for the times you will need to bend your arm 13 different directions at once to reinstall some of the new header bolts.
MODS IN GARAGE
NCMM ORIGINAL
Old October 12th, 2008, 12:46 PM   #20
texas96gt's Avatar
n/a
texas96gt is on a distinguished road
Are the stock manifolds held on by nuts or do they have bolts. I just bought some FRPP headers and some stage 8 header bolts. If they are held in by nuts how hard it is to remove the studs?
Threads Similar to: Shortie Header install
Header Install RAGEman 99-04 20 April 7th, 2008 07:26 PM
header install cali 5.0 99-04 11 February 17th, 2008 03:19 PM
Header install HMStang217 99-04 13 January 8th, 2008 08:33 PM
BBK tuned shortie header install! 2000mgt 99-04 2 October 30th, 2007 03:10 PM
header install dumps 2005 - 2010 8 May 18th, 2007 02:25 AM
