Discussing Lifting a Mustang (Cobra) in the 96-98 Forum. Butchered......just a tad harsh considering nothing has really changed yet. The fun starts tomorrow ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
#61 |
1996 SVT Cobra
![]() The fun starts tomorrow when the UPS man delivers the UPC k member, A arms and coil over conversion, Have a little faith brother.
![]() TREADMARKS Candy Laser Red Metallic 1996 SVT Cobra 1367 of 7496 Diablosport, 2.5 X-pipe, Flowmasters, Steeda Cold Air, Triax, Crossbraced Subframe Connectors, UCAs, Tokicos, GMS adj LCAs, UPR k-Member, control arms and 14x175 Coil Overs. |
#62 |
1998 mustang gt
12.6@110
how can anyone say butchered lol... it really doesnt look that much diffrent...do any of you know the ride height of a sn95...i'd say it looks more "stock" then anything...i take back everything i said in the begining....
#63 |
1996 SVT Cobra
Adjusted the rear springs a little more and got a few shots.
#64 | |
1996 SVT Cobra
It will heal. ![]() I bet next time I bag ass down that same road, all will be well.
#65 |
1998 Mustang GT
haha. well whatever happens to this thing, i really wanna c some video of the off-roadin
1998 GT PI cams bbk cai flowmaster 40's catback bbk x-pipe w/ cats march pulleys RAM clutch Steeda Tri-axe |
#66 | |
1996 SVT Cobra
#67 |
1996 SVT Cobra
Here Comes Santa
Geez I like the UPR stuff.
I don't know if I should just put it on, or get naked and roll around on the ground with it. It will be a far sight from butchered. I will start the teardown today. It wont be anything like the lift I put on my truck 100,000 miles ago, but it will smooth out the crappy roads I drive on. I am open to any suggestions from someone who has done a k member before.
#68 |
1997 Mustang Cobra
1/8 - 8.89@86mph
wow looks better than i pictured in my head... i was picturing a hick mobile on big ol mud tires... lol
oh yeah about that K member... I just did mine about 4 months ago... got the same kit as you... PAIN IN THE ASS! but i did the headers at the same time and the headers made the k member seem harder... so the k member isnt all that hard. fly me down ther and Ill gladly help you! ![]() just ask any question... ill try to type a breif guide... |
#69 |
1997 Mustang Cobra
1/8 - 8.89@86mph
1. break front lugs loose
2. raise and support car 3. take front wheels off 4. take calipers off and support them/hang using wire up and out of the way 5. remove front springs 6. remove strut assembly and knuckle 7.remove steering shaft pinch bolt and remove shaft from rack and pinion 8. remove rack and pinion 9. place jack under oil pan and place piece of wood between jack and oil pan and jack it up intill it contacts and after contact slightly pump it up 1/4in more. 10. remove k member bolts 11. support k member 12. remove engine mount nuts 13. lower k member from car 14. lift new k member up into place 15. tighten bolts \ nuts 16. install a arms and a arm bushings 17. put coil over kit onto strut assembly 18. put strut ass. on a arm 19. tighten etc etc etc etc you get the jest. oooh and btw you need to go and buy some shorter bolts for the rack n pinion... I was pissed the kit didnt come with the bolts... it ounds easier than it is and i probly missed a couple things but if you have any ??? just let me know...
#70 |
1997 Mustang Cobra
1/8 - 8.89@86mph
I had a problem with the coil overs bottoming out because it was too low but i doubt your going to have that problem...
Good luck!
#71 |
1996 SVT Cobra
Same kit...no chit...cool. How may hours do ya think it would take? Any alignment issues? Any regrets?
#72 |
1997 Mustang Cobra
1/8 - 8.89@86mph
no alignment issues just need to get it aligned after working with suspension every time. yeah same kit! costed me like 1000.00. lol the only regret was that i put it on my CC and made me more in debt.
other than that its a great kit! kinda sux when you have to modify you struts for the coil overs though... that part sux!
#73 |
1997 Mustang Cobra
1/8 - 8.89@86mph
oh and it depends on how many times you have to run to the part store, and if your spindel bolts are frozen. PITA! also the little plate for the coil over tube to slide off takes an hr. so it should only take about 6-8hrs I had to do mine in a freezing garage when the temp varried from -5 - 0 degrees so yeah i had to take a lot of warm p breaks. lol somthing tells me you wount have to worry about that.
#74 |
1996 SVT Cobra
No need for warm p breaks, maybe cold beer breaks though.
![]() Thanks for the heads up, all should go well.
#75 |
1996 SVT Cobra
Well, It's almost all the way in 2 hours last night. Left ball joint was a major pita to break loose.
![]() Only thing left is to remove steering shaft pinch bolt and remove shaft from rack and pinion. I can't see chit under there. Can someone point me to the pinch bolt.
#76 |
1996 SVT Cobra
Nevermind. Got it.
#77 |
1996 SVT Cobra
alot of stedda ftuff gon.Everytrhiing worked perfect for me
#78 |
1996 SVT Cobra
So about two hours Friday night and six hours Saturday and she is done. Pretty straightforward install, would have been nicer if UPR had included some instructions. Thanks 97, your list came in pretty handy.
Since I had no formal instructions for the k-member or lube for the LCAs assembly, I went ahead and installed zerk fittings on the LCAs. My stock outer tie rod ends were in good shape but lacked zerks so they got replaced as well. She sits a good bit higher than she did brand new twelve years ago. She will surely need some new rubber to fill up the fenders. I will do a shade tree alignment today to get her to the shop tommorrow morning so I can see how she drives. May wind up flipping the C/C plates to provide more down travel.
#79 |
1997 Mustang Cobra
1/8 - 8.89@86mph
pinch bolt is bout the easiest thing on the install....
goodjob! only bad thing is the more road noise but i like mine!
#80 |
1996 SVT Cobra
Three hours at the alignment shop this morning. The good news is that most of the guys working there drive mustangs, so they had a blast doing the alignment. The bad news is that my coil overs are pretty close to the inside of the tires. Not rubbing, just a little close. I would like to space out the front wheels about 1/4" and the rears about 1/2". Does anyone make safe spacers? I will look for those next.
Left the alignment shop and went to the exhaust shop. Went with a new (unflattened) x pipe and flowmasters in 2.5" with 3.5" slash cut stainless tips. Man that 32 valve motor sounds sooo sweet with the flowmasters. A little loud...but still sweet. So now the car starts, drives, sounds and stops perfectly for me. I love the extra travel in the suspension, really smooths out the crappy roads here. Still corners very well too with the fat steeda swaybars. Looks like wheel spacers, taller tires and a nice tune are next on the list.
Threads Similar to: Lifting a Mustang (Cobra)
| Lifting the gas pedal | 96GtGoodz | 96-98 | 2 | December 15th, 2007 02:33 PM |
| Lifting a car with a hose | TurboLX | The Clubhouse | 1 | October 22nd, 2007 07:52 PM |
| lifting the car | Luis_GT | 2005+ | 10 | October 14th, 2007 10:33 AM |
| weight lifting | mpboy | The Clubhouse | 207 | September 4th, 2007 01:29 PM |
| Lifting My Car | rene9 | 96-98 | 5 | October 1st, 2006 11:15 PM |
