97 GT rear brake calipers, Help Please..
Old April 24th, 2008, 08:55 PM   #1
1979&1997 Mustang
79StangPace is on a distinguished road
I was doing my rear brakes cause the pads were really bad.. Got the pads off, inspected the rotors, looked ok to put new pads on but having a problem compressing the caliper. Is there a trick to this or is it the same as any other caliper cause Ive done a thousand brake jobs but these are being very stubborn. Any advise is appreciated. Thanks.
1997 Mustang GT Auto, (Fenderwell CAI), O/R X-pipe, Flowmasters, 3.73's, tuner, 180*stat...
1979 Mustang, 302 .060ov, KeithBlack's, Comp's, Weiand Stealth Intake, Holley 650dpr, 2800TCI, Hedman LT's, Flows, 410's, Welds, M/T Slicks and More..
Old April 24th, 2008, 08:58 PM   #2
HMUSN's Avatar
48.47@ 12.58
iTrader: 11 reviews
yes.. it's a twist type caliper. your local parts store sells a special tool for it.. it's rather cheap. or you could use a pair of pliers
Old April 24th, 2008, 09:41 PM   #3
1979&1997 Mustang
With Pliers, is that twist and compress at the same time or?
With tool?
Direction of twist to compress?
Thanks
Old April 24th, 2008, 09:43 PM   #4
HMUSN's Avatar
48.47@ 12.58
iTrader: 11 reviews
clock wise.
and yes it is at the same time as compression. with the tool.
Old April 24th, 2008, 10:49 PM   #5
97GT4.6's Avatar
97 GT
14.2@99.8 @ 4800 ft
97GT4.6 has a spectacular aura about97GT4.6 has a spectacular aura about97GT4.6 has a spectacular aura about
Send a message via AIM to 97GT4.6
Yea, with out that tool ,its really difficult, and HMUSN im really excited to see you back.
Cammed 2v
Built By MustangMatt
More mods than times your daughter has slept around
Old April 25th, 2008, 08:24 AM   #6
Muscletang's Avatar
1997 SVT Cobra
Muscletang is a splendid one to beholdMuscletang is a splendid one to beholdMuscletang is a splendid one to beholdMuscletang is a splendid one to beholdMuscletang is a splendid one to beholdMuscletang is a splendid one to beholdMuscletang is a splendid one to behold
I've done it without the tool so it can be done as they said but with the tool and it is much easier.
Old April 25th, 2008, 09:09 PM   #7
1979&1997 Mustang
Got it done today. Had to get the tool from autozone and it worked great. My major problem was one of the floating pins on the caliper bracket seized and made the inner pad wear out and scar the rotor. Took a torch to the bracket and the pin fell right out. Bought the pin kit, repacked with grease and worked like a champ. Thanks for your help guys.
Threads Similar to: 97 GT rear brake calipers, Help Please..
brake calipers Toph6888 V6 Mustangs 6 April 24th, 2008 12:32 PM
Has anybody rebuilt the rear brake calipers. RandySiemens 96-98 1 October 14th, 2007 09:26 PM
Brake Calipers Jucostud 2005 - 2010 14 October 10th, 2007 01:10 AM
Polishing Brake calipers on 99+ marknlori V6 Mustangs 0 May 21st, 2007 07:43 AM
brake calipers dman General Tech 0 January 2nd, 2007 08:45 PM
