Discussing Gear Grinding... in the 96-98 Forum. Hey guys, I need some help on this one, anytime im REALLY getting on my ...
Old October 23rd, 2006, 11:15 PM   #1
Gear Grinding...
Hey guys, I need some help on this one, anytime im REALLY getting on my car, and slammin the gears, 4th and 5th gear grinds pretty bad, but ONLY 4th and 5th Gear, what is the deal with that? someone told me that it could be my synchronizers going out.... or is it my tranny, or rear end? I need help PLEASE!!!
thanks,
Jeremy
1998 Mustang GT Super Charged! CGS Sub frames, Auto Meter gauges, Bassani Exhaust!
Old October 23rd, 2006, 11:41 PM   #2
sounds like transmission..i would go ahead pull it out and rebuild it...me and my dad rebuild transmission for a living..
Old October 24th, 2006, 12:37 AM   #3
no shit? that sux... i really don't want my tranny to be bad! but yeah, since you rebuild them for a living you would know...right, its only in 4th and 5th gear, BUT only when i'm SLAMMIN the gears, when i ease on the gears, it has NO problem, shifts fine, but when i slam them fast, it grinds, then goes into gear.
Old October 24th, 2006, 12:43 AM   #4
97Cobra's Avatar
1997 Mustang Cobra
1/8 - 8.89@86mph
how about............not slaming them? lol no well i know that when your really getting on it and slamming gears it could be possible that your letting off the clutch to soon. I know my step dad gets a lil to inthusastic and lifts up his foot befor he gets it into gear. plus it amplifies with a SC. lol but if your hitting themright it could be your syncros. or you could go the expensive route of a rebuild. lol hope this helps
Modifications and pics in my Garage...
same shit happened to me a few years ago.turns out the chick was indeed a slut. i never talked to her again
Originally Posted by 96GTRagTop View Post
must be real weird at the dinner table not talking to ur mom and all
Old October 24th, 2006, 12:43 AM   #5
97Cobra's Avatar
1997 Mustang Cobra
1/8 - 8.89@86mph
good luck
Old October 24th, 2006, 12:48 AM   #6
how would i go about checking my synchros? is it costly to change them, and not to mention how hard?
Old October 25th, 2006, 02:33 PM   #7
Casper98GT's Avatar
If it only happens in high rpms, youre syncros are not meshing properly. It happens alot in these cars. If you have a TR-3650 Ford has a TSB out for that problem. Upgraded parts. I can email you the TSB if you want, just PM me.
You could always double clutch it, if you wanted to. Might help.
The cost depends on where you bring it.
White99stang-
Damn i miss the good ole days, you know in 2005 when the site first started and everyone wasn't getting butt hurt over every little thing
Ford/Toyota tech.
93 LX, H/C/I + Vortech
Old October 25th, 2006, 04:34 PM   #8
exactly what does that mean.... double clutch? exactly what it says, just push the clutch in twice?
Old October 25th, 2006, 07:27 PM   #9
Casper98GT's Avatar
http://www.wisegeek.com/what-is-double-clutching.htm
White99stang-
Ford/Toyota tech.
Old October 25th, 2006, 08:01 PM   #10
wow, i didn't know it was that easy.....
Old October 25th, 2006, 08:59 PM   #11
how fast are you going to be really getting on it and slamming it into 5th? That's a gear for cruising...
95 Mustang GT
Slow Bolt On Car
http://img61.imageshack.us/img61/8386/sig4rx2.jpg
www.steelcitystangs.com
Old October 25th, 2006, 09:01 PM   #12
Casper98GT's Avatar
If you dont have alot of power or not much gear you may be shifting into 5th in the 1/4.
White99stang-
Ford/Toyota tech.
Old October 25th, 2006, 10:21 PM   #13
well when i'm on the interstate trying to get to work, passing as many ppl as i can, i'm usually going to about 80-95mph, 4th allows me to go about 55 thats when the rpms are REALLY getting up there, when i say SLAMMIN the gears, i really mean, just shifting at a fast pace, but i think i am letting out on the clutch to soon.....
Old October 30th, 2006, 10:40 PM   #14
i think i know what your talking about. i just installed a short throw shifter and i went to test it out and when i really went to slam it into second it would grind and go into gear. the rpms didnt seem to matter. so then i thought i was either not pushing the clutch in all the way or letting out too soon so i just held the clutch in and slammed it into second and it still did some grinding so its prolly has nothing to do with your clutching. just my .02
Old October 30th, 2006, 10:43 PM   #15
Casper98GT's Avatar
phil, did it do it before the short throw? If not.... you might wanna adjust youre throw stops. You might have them unadjusted and could be causing problems with them like this. Adjust them ASAP.
White99stang-
Ford/Toyota tech.
Old October 30th, 2006, 10:48 PM   #16
97Cobra's Avatar
1997 Mustang Cobra
1/8 - 8.89@86mph
yeah and if its steeda Short throw its tidieous adjusting them!
Old October 31st, 2006, 01:31 AM   #17
i dont know if it did it before the short throw shifter because i never really tryed to shift that fast. i set the stops just as the directions said but maybe i need to go back and check them. it works fine if i just shift normal its when i try and skip that little "hitch" in neutral when it does it.
Old October 31st, 2006, 10:52 AM   #18
97Cobra's Avatar
1997 Mustang Cobra
1/8 - 8.89@86mph
you have to adjust the stops A LOT it gets anoying after awhile......
Old October 31st, 2006, 07:19 PM   #19
i adjusted my stops today but i dont think that was the problem. it seems that its grinding right past neutral when going into the next gear. its kinda hard to explain but if you shift slow you can feel a little "hitch" when gonig through neutral and it seems to grind when i try and shift fast and hard enough to skip this "hitch". i dunno, all i have to do is not shift quite as fast and its fine.
Threads Similar to: Gear Grinding...
gear grinding Blk01ponyGT 99-04 22 September 19th, 2007 05:02 PM
Grinding after the track weems 99-04 58 July 13th, 2007 07:37 AM
t5 grinding in reverse tayboo24 5.0 Mustangs 19 June 4th, 2007 12:20 AM
1st gear grinding Luis_GT 2005+ 9 April 4th, 2007 07:05 AM
tranny grinding terribleonexx88 5.0 Mustangs 12 October 18th, 2006 11:13 PM
