LinkBack (1) | Thread Tools |
#1
97 4.6L
is this intake legit? please help
96-98 Mustang GT 4.6 4.6L Performance Intake Manifold
15-20 More Horse Power and Better Throttle Response This kit has been thoroughly researched, developed and assembled with quality parts. It has larger runners which allows for greater air flow. This kit produces the greatest horse power gain per dollar over any other modifications with the exception of Nitros and Super Charger. I have this kit install on my 98 Mustang GT! It took me approximately 4 hours to complete (Including taking a couple pictures and notes). MY CAR RUNS AND SOUNDS INCREDIBLE! You can expect the following noticable benefits: 15-20 Horse Power Gain Improved Throttle Response Improved RPM Range Improved Fuel Economy Improved Exhaust Tone 1-Year Warranty Included Applications: 1996FORDMUSTANG: GTV8 - 4.6L (281 CID): GAS: FI: N: X1997FORDMUSTANG: GTV8 - 4.6L (281 CID): GAS: FI: N: X1998FORDMUSTANG: GTV8 - 4.6L (281 CID): GAS: FI: N: X $289.99 |
97 4.6L
bump....
Smelly Fists, Socking Cocks
Millenium Falcon
yes
97 4.6L
it has the aluminum cross over with both temp sensores. same as 96-98 intakes. so is this like a pi intake with the crossover swaped?
Millenium Falcon
no, it's just an updated PI intake with a pre taped temp sen.
97 4.6L
thanks man....
so do i have to still use silicone around the ports like installing pi intake on npi heads or will it bolt up like a npi intake? |
Millenium Falcon
still need the silicone
97 4.6L
thank you for the help.....
97 4.6L
you have pi intake and cams swaped rite?
Millenium Falcon
no need to thank me, rep me insteads........
click the scale under my name and hook a brada up |
Millenium Falcon
97 4.6L
you notice any differences? like throught the rpm's and exhaust note?
1965 Mustang Fastback
why not the heads
![]() you could get puttin like what 300 to the wheels ?
I'm a good boy now. [COLOR=red][B]slow car club - crew member 7 of 9 [COLOR=White]Mood: Cool :cool: [/COLOR][/B] [/COLOR] |
97 4.6L
theres not much difference from npi to pi heads..... if im correct the power comes from the intake and cams......
#15 | |
Millenium Falcon
![]() ![]() My car stops making decent power at about 6k.......orginally she gave out at about 4900.... (3000 when i cracked the intake) Exhaust got a little bit more Gurgly, but i swapped the catback out within 2 weeks. I did each mod sep..... Intake then cams. At first the car ran up to 6k, but she felt jumpy, and not smooth. When we put the cams in, all that went away, and the car started running like mint. |
97 4.6L
am i rite about my last reply? how was doin the cam swap, you have problems with the cam caps or timing?
#17 | |
Millenium Falcon
U only make 300 hp to the wheels with an open exhaust, tune, and AfterMarket Cams. I've got stock cams out of a 02 or 03..... whatever year GTSetGo's car is.
![]() I plan on boosting my car in the near future, and the heads raise ur combustion and won't allow me to run more then 12lbs without breaking something. the 5-20 potential HP id gain from the heads would wind up costing me $$$ sooner then i'd like it too. |
#18 | |
Millenium Falcon
![]() me and my buddy had a bitch of a time with the cam caps. One side, fucker popped on us, and we had to do some searching for bolts. also, cause my heads were on the car, some of the rocker arms (not sure if im right) that sit under the cam were to far advanced (thats what caused the pop) and luckily enough another mechanic showed up to pick up a tool on his day off and lent us a hand. as far as timing, i held it in place each time while my friend inserted the cam..... so yeah, it was a bitch as well. Took us about an hour to get the bad side swapped in and out.
97 4.6L
yeah im tryin to figure out what to do rite now, i got the hole pi swap sittin in the garage rite now i just dont know what path to go down..... the raised compression sucks and id rather have my heads redone.
97 4.6L
you break any of the gridles?
LinkBack to this Thread: http://www.moddedmustangs.com/forums/96-98/68897-intake-legit-please-help.html
| Gas Chargers unearthed. » Blog Archive » Quick Roundup | This thread | Pingback | May 1st, 2008 02:04 PM | |
Threads Similar to: is this intake legit? please help
| short ram intake or cold air intake????? j/w | Stangbro8994 | V6 Mustangs | 32 | September 18th, 2008 09:20 PM |
| is this supercharger legit? | 03StangGT | 99-04 | 7 | February 24th, 2008 08:21 PM |
| seems legit | bigbadwollfff04 | 99-04 | 1 | April 25th, 2007 02:37 PM |
| 95' Mustang 5.0 HO intake swap for 93 cobra intake... | stang9587 | 5.0 Mustangs | 1 | April 3rd, 2007 06:20 AM |
| Need help using a 5.0 upper intake on a 5.8 lower intake | Washington5.0 | 5.0 Mustangs | 4 | March 9th, 2007 02:54 AM |
