PI Swapped Intake Manifold coolant temp sensors? manifold came with one and i need two...who ever has this problem and fixed this, did youu get any shavings in the coolant when you drilled the hole????if so would it mess anything up and if you didnt how the hell did you manage that? thanx for any help..
Until you calm down you get NO help!!! it is a very easy process..... Go slow when drilling use alot of grease on the drill bit and tap.... take a chill be calm and it will be ok ........the key is to take your time.
k but if i did get shavings in the coolant would it hurt anything??
MAYBE IT DEPENDS ON WHAT SYSTEM YOU HAVE I WOULD HAVE A MEC CONSULT TO BE SAFE
LOOKIN' FOR MY "MUSTANG SALLY!" . . . . . . ARE YOU OUT THERE? |
hey im planing on doing my swap soon i got the parts allready... what size hole/thread tap do you need to drill and approx where on the crossover, id rather do it before i take it all apart and take my time thanks
#6 | |
I could have sworn i just replyed to this but i guess not. lol
You should have done youre homework before hand. You need to drill and tap before you install.
You have some choices here.... 1. remove the manifold and drill and tap. 2. Drill and tap in car, which i DONT recommend. Ok. 3. remove youre block drain and install the sensor there. You have to lenghten youre wires, but it works. The block drain most of the time is under youre drivers side exhaust manifold. No need to remove the manifold though. TLGRANT : Yes the drill tap size i cant remember but if you look in these 96-98 post section i actually tell you the size when i do the"HOW TO" on installing the PI manifold on a NPI car. It IS pipe thread. So remember that. I would suggest just taking youre manifold and sensor and asking a machine shop to drill and tap. Tell them you have no clue what size and they can figure it out. I have done it for friends and cost me all of 15 dollars. Hope this helps...
91 LX, 5spd. Ex:Toyota/Ford tech Marine Machinery Technician, Department of Defense.
Threads Similar to: PI Swapped Intake Manifold
| Swapping a 98 V6 intake manifold with for a 99 V6 manifold | 98mustang | V6 Mustangs | 6 | November 20th, 2010 11:20 PM |
| Intake Manifold | KLance221 | 96-98 | 19 | April 11th, 2007 01:16 PM |
| Help Intake Manifold | stang94 | 5.0 Mustangs | 8 | October 26th, 2006 01:38 PM |
| New Intake Manifold.. | 96_gt_stanger | 96-98 | 13 | October 24th, 2006 03:16 PM |
| intake manifold | ayyubam2002 | General Tech | 2 | July 9th, 2006 12:13 PM |
