Discussing Cylinder 3 misfire. P0303 in the 96-98 Forum. 02's....... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
#21 |
08 GT
02's....
NObama '08 KEEP the 2nd amendment ALIVE!!! I've got a 2008 Mustang GT, Bolted w/ 4.10's. And a Drag Truck... LIFE IS GOOD! |
#22 |
14.879@91.24 @ 5800 FT
sounds like O2 sensors too me.
![]() We expect shit to break, look foward to realizing exactly when it is happening, and than obsess about dropping plenty of cash to rebuild stronger, so we can try to run it hard as hell and break again. We are sick individuals.
#23 |
1997 mustang gt
8.06 at 87mph 1/8th mile on a 50 shot
tell ya what when the car is running pull the plug wire off and see if i changes how the car runs at an idle. then report back
also miles?
97 gt with 2004 pi motor,acufab intake and 75 mm bbk cold air kit,bbk long tube headers, off road h pipe,2 chamber flow, 3:73, diablo chip with dyno tune 269rwhp 301rwtq |
#24 |
check your coolant level. sounds like to me there might be an intake leak getting to the spark plug hole and either fouling the plug or building pressure under the plug wire boot and blowing the wire off the plug or causeing it to crossfire to the aluminum head.
1997 Mustang Gt Convertible for sale. Triple black, great condition and unmolested!http://www.moddedmustangs.com/forums...like-most.html |
#25 |
no all the gaskets in the motor are new...i have alot of bolt ons on my car.. I have BBK shorties, U/D pullies, TB, upper plenum, CAI, slp cat back with pypes O/R with high flow cats, ffrp 24lb injectors.. the oknly thing i dotn have is a Bigger MAF.. Could that cause the problem??/
#26 |
#27 |
is it tuned for the 24 pound injectors?
#28 |
the only way you are getting a misfire on #3 cylinder is spark plug, wire, coil pack , water in plug boot, or faulty injector
#29 | |
but it could run like crap without a tune for the injectors and it could be part of the running bad.
#30 |
i dont have a tune or a bigger MAF? but it isnt throwing the misifire code anymore but it is still stumbling..idk what else could cause it..help/.
#31 |
y do you have bigger injectors? esp with no tune?
#32 |
i got the injectors because i was planning on tuned and didint want to tune it with out the bigger injectors...
#33 |
on the two downstream oxygen sensors, wat are the colors you are supposto match up...i wonder if they are mismatced...would that cause it to run like crap????????
#34 |
the injectors are wat is making it run like crap. Put in the stockers to make it run and then put in the larger ones when you tune for it.
YOu will ruin the motor if you run those injectors too long without a tune.
#35 |
oh shit dude if you have larger injectors you HAVE, I mean you MUST have the MAF replace or calibrated to match, thus a tune! Your flooding the hell out of the engine dude. WOuldnt surprise me if your oil doesnt smell like gas. I bet your washing the cylinder walls down. Put in stock injectors and change oil run engine 5 mins ,change oil again.
#36 | |
Check compression in that cylinder you might be wasting youre time when you have a bad cylinder or valve. 19 to 24lbers...would make it run bad and as well as ruin youre cats and im thinking by now you would have a po420 or po430. I dont think youre doing much damage by running the 24's. the older fox'es with their shitty computers had a big problem trying to compensate for the injectors. But the new computers would adjust to a certain point. I would recommend a tune or a new MAF if youre planning on keeping them but i in no way think its the reason for a ONE cylinder misfire. The only thing that would happen from the MAF would set a rich code ( po171 but would also set po172 ) would set both due to both banks being rich. I dont understand the cylinder 3 thing. I would think it would set both those codes first. Maybe i dont know the entire story. I dunno.
Ford/Toyota tech. -93 LX, X303 heads, F-cam, Trickflow u/l, 1.6 RR, FR wires, MSD cap/rotor, Elec. fan, a/c delete, smog delete, sn95 fuel rails with BBK regulator, 75mm TB and EGR, Vortech S-trim w/intercooler, 42lb inj/PMAS, 3.55's - |
#37 |
its no longer getting the misfire though... just running rough.
#38 |
Getting any codes?
#39 |
Your right casper. I just stated the obvious causes of the p0303. Ya know how hard it is to diag online, especially if the owner doesn't know much about the vehicle or how it works. Everyone with a 96+ mustang or ford needs and IDS!!!!!! Wish I had a PDS myself.
#40 |
That would be awesome to have an IDS just laying around, haha..
So the owner of this thread ever check back ???? Are you just getting a po171/172....if you are. You need a tune, MAF or 19lb's back in the motor. Thats the cause. Plain and simple.
Threads Similar to: Cylinder 3 misfire. P0303
| misfire | riddlee josh | V6 Mustangs | 20 | January 19th, 2008 09:41 AM |
| Cylinder Misfire!!!!! | ivan48humble | 2005+ | 4 | January 17th, 2008 06:57 PM |
| cylinder #8 misfire | tallman20 | General Tech | 4 | October 14th, 2007 04:11 PM |
| cylinder 6 misfire | Jucostud | 96-98 | 4 | May 10th, 2007 11:46 PM |
| misfire.... | stang fanatic | General Tech | 10 | June 23rd, 2006 10:08 AM |
