Discussing Cylinder 3 misfire. P0303 in the 96-98 Forum. 02's.......
Old May 9th, 2008, 10:11 PM   #21
qwik48r's Avatar
08 GT
02's....
NObama '08
"Because the 2nd amendment ain't about duck huntin'...."
I've got a 2008 Mustang GT, Bolted w/ 4.10's.
And a Chevy Drag Truck... LIFE IS GOOD!
Hurst Crew #18
Old May 10th, 2008, 12:34 AM   #22
MustangMatt96GT's Avatar
13.023@103.46 @ 5800 FT
sounds like O2 sensors too me.
We expect shit to break, look foward to realizing exactly when it is happening, and than obsess about dropping plenty of cash to rebuild stronger, so we can try to run it hard as hell and break again. We are sick individuals.
Old May 10th, 2008, 10:10 AM   #23
bigmike83's Avatar
1997 mustang gt
8.06 at 87mph 1/8th mile on a 50 shot
tell ya what when the car is running pull the plug wire off and see if i changes how the car runs at an idle. then report back
also
miles?
97 gt with
2004 pi motor,acufab intake and 75 mm
bbk cold air kit,bbk long tube headers,
off road h pipe,2 chamber flow,
3:73, diablo chip with dyno tune
269rwhp 301rwtq
Old May 10th, 2008, 04:00 PM   #24
ujslost's Avatar
check your coolant level. sounds like to me there might be an intake leak getting to the spark plug hole and either fouling the plug or building pressure under the plug wire boot and blowing the wire off the plug or causeing it to crossfire to the aluminum head.
http://www.moddedmustangs.com/forums/vehicle-classifieds/86839-wtt-90-lx-hatch-red-black-north-alabama.html#post1394801
Old May 12th, 2008, 11:53 PM   #25
no all the gaskets in the motor are new...i have alot of bolt ons on my car.. I have BBK shorties, U/D pullies, TB, upper plenum, CAI, slp cat back with pypes O/R with high flow cats, ffrp 24lb injectors.. the oknly thing i dotn have is a Bigger MAF.. Could that cause the problem??/
Old May 17th, 2008, 09:46 PM   #26
Old May 17th, 2008, 09:48 PM   #27
is it tuned for the 24 pound injectors?
Old May 17th, 2008, 10:40 PM   #28
ujslost's Avatar
the only way you are getting a misfire on #3 cylinder is spark plug, wire, coil pack , water in plug boot, or faulty injector
Old May 17th, 2008, 10:42 PM   #29
+1
but it could run like crap without a tune for the injectors and it could be part of the running bad.
Old May 18th, 2008, 05:18 PM   #30
i dont have a tune or a bigger MAF? but it isnt throwing the misifire code anymore but it is still stumbling..idk what else could cause it..help/.
Old May 18th, 2008, 06:36 PM   #31
nes
y do you have bigger injectors? esp with no tune?
laser red 98 gt- stock
Originally Posted by supermachone View Post
psh dude i slit throats all the time
Old May 18th, 2008, 09:18 PM   #32
i got the injectors because i was planning on tuned and didint want to tune it with out the bigger injectors...
Old May 19th, 2008, 07:05 PM   #33
on the two downstream oxygen sensors, wat are the colors you are supposto match up...i wonder if they are mismatced...would that cause it to run like crap????????
Old May 19th, 2008, 10:35 PM   #34
the injectors are wat is making it run like crap. Put in the stockers to make it run and then put in the larger ones when you tune for it.
YOu will ruin the motor if you run those injectors too long without a tune.
Old May 19th, 2008, 10:48 PM   #35
ujslost's Avatar
oh shit dude if you have larger injectors you HAVE, I mean you MUST have the MAF replace or calibrated to match, thus a tune! Your flooding the hell out of the engine dude. WOuldnt surprise me if your oil doesnt smell like gas. I bet your washing the cylinder walls down. Put in stock injectors and change oil run engine 5 mins ,change oil again.
Old May 21st, 2008, 11:46 PM   #36
Casper98GT's Avatar
+1
Hahaha. A Cylinder 3 misfire would be caused by alot. I will agree Plug, wire, coil pack or injector. But you could also have alot more. Bad piston rings from a washed down cylinder, could have a stuck valve. Maybe some carboned valves. You never know exactly what it is unless you do some diag on it.
Check compression in that cylinder you might be wasting youre time when you have a bad cylinder or valve. 19 to 24lbers...would make it run bad and as well as ruin youre cats and im thinking by now you would have a po420 or po430. I dont think youre doing much damage by running the 24's. the older fox'es with their shitty computers had a big problem trying to compensate for the injectors. But the new computers would adjust to a certain point. I would recommend a tune or a new MAF if youre planning on keeping them but i in no way think its the reason for a ONE cylinder misfire. The only thing that would happen from the MAF would set a rich code ( po171 but would also set po172 ) would set both due to both banks being rich. I dont understand the cylinder 3 thing. I would think it would set both those codes first. Maybe i dont know the entire story. I dunno.
White99stang-
Damn i miss the good ole days, you know in 2005 when the site first started and everyone wasn't getting butt hurt over every little thing
Ford/Toyota tech.
93 LX, H/C/I + Vortech
Old May 21st, 2008, 11:49 PM   #37
its no longer getting the misfire though... just running rough.
Old May 21st, 2008, 11:53 PM   #38
Casper98GT's Avatar
Getting any codes?
White99stang-
Ford/Toyota tech.
Old May 22nd, 2008, 07:47 AM   #39
ujslost's Avatar
Your right casper. I just stated the obvious causes of the p0303. Ya know how hard it is to diag online, especially if the owner doesn't know much about the vehicle or how it works. Everyone with a 96+ mustang or ford needs and IDS!!!!!! Wish I had a PDS myself.
Old May 22nd, 2008, 07:54 PM   #40
Casper98GT's Avatar
That would be awesome to have an IDS just laying around, haha..
So the owner of this thread ever check back ???? Are you just getting a po171/172....if you are. You need a tune, MAF or 19lb's back in the motor. Thats the cause. Plain and simple.
White99stang-
Ford/Toyota tech.
Threads Similar to: Cylinder 3 misfire. P0303
misfire riddlee josh V6 Mustangs 20 January 19th, 2008 09:41 AM
Cylinder Misfire!!!!! ivan48humble 2005+ 4 January 17th, 2008 06:57 PM
cylinder #8 misfire tallman20 General Tech 4 October 14th, 2007 04:11 PM
cylinder 6 misfire Jucostud 96-98 4 May 10th, 2007 11:46 PM
misfire.... stang fanatic General Tech 10 June 23rd, 2006 10:08 AM
