idle
Old May 13th, 2008, 01:05 AM   #1
.000000000000001
dopeman(me) is on a distinguished road
idle
My is idling low after it's warmed up it would normally be right about 1k but but now it starts to go from 1k to 500k sometimes it seems like it's gana die what could be the problem
I got that vtech
Old May 13th, 2008, 01:06 AM   #2
NMR-2vGT's Avatar
1996 GT
Too Slow....
NMR-2vGT will become famous soon enough
Send a message via AIM to NMR-2vGT Send a message via MSN to NMR-2vGT
IAC
1996 Mustang GT, Full PI Swap, MGW Shifter, Magnaflow Cat-back, K&N Filter
MM Unite For Bubba
Old May 13th, 2008, 01:07 AM   #3
HMUSN's Avatar
iTrader: 9 reviews
tps. aic.. clean your maf..
tps throttle position sensor
aic aid ilde control sensor
maf mass air flow sensor..
Old May 13th, 2008, 01:08 AM   #4
Smelly Fists, Socking Cocks
G.T. Rags's Avatar
Millenium Falcon
G.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant future
ur idle should stay around 600 rpms after she's warmed up.
When i cold start my car the rpms jump to 1500, then drop down to 1000 withing 10 seconds, and then from there, depending on how cold it is, my car will slowly drop down to 600.
If she stalls or seems like she's about to stall u should clean ur IAC. If that doesn't help, possibly a tune up and change the fuel filter
I would eat the peanuts out of her shit
Car Salesman Club - The Hammer
ModdedMustangs Conspiracy Group: President
Old May 13th, 2008, 01:09 AM   #5
.000000000000001
it it hard to clean
I got that vtech
Old May 13th, 2008, 09:04 AM   #6
The Doctor
Lefty's Avatar
'01 Cobra Vert.
iTrader: 11 reviews
no...pull it off right from the throttle body. take some carbon cleaner (just something to clean the carbon build up on the inside of it) and clean it out. after you spray it let it sit a little bit and put her back on =)
Old October 12th, 2008, 04:38 PM   #7
Forest Green 1994 GT
MaverickGT is on a distinguished road
LOL,
My car is doing this as well, Thanks for the info.. I am gonna clean my IAC and MAF, See if it makes a diff.. mine idles around 500 when warm.. and it
will dip real low every 10 secs or so to like 300. It never stalls.. but comes close..
Thanks
Don
Old October 12th, 2008, 04:40 PM   #8
Proud American
MustangMatt96GT's Avatar
Typically its a IAC, i had cleaned mnine a few times and turns out i had to put on a new one. Fixed my idle and stubling issues...
RIP Travis Billings
Special Thanks to:
Andrews Racing Transmissions
Baseline Suspensions
Never Lift Racecars
Old October 12th, 2008, 04:49 PM   #9
Yeah..
I am gonna try cleaning it and my MAF, see if i can get it to stop if not, I'll replace it.. what do they cost new any idea?
Don
Old October 12th, 2008, 04:51 PM   #10
Proud American
I paid 55 bucks 2 weeks ago
RIP Travis Billings
Special Thanks to:
Never Lift Racecars
Old October 12th, 2008, 04:52 PM   #11
kk,
Cool. I will see how the cleaning goes.. 55 is not bad..
Thanks
DOn
Old October 12th, 2008, 08:43 PM   #12
ndfrspd's Avatar
1998 Mustang GT
1:34.43@13.86
ndfrspd is infamous around these parts
i got the same problem, my dad kinda adjusted the throttle cable on the throttle body and it dropped down to about 600 rpm where it should be, but when it starts up it goes up to 1500 and then slowly dips down about 10 seconds later. I read somewhere that theres a manifold sensor that monitors pressure and regulates the air and fuel mix, and i have a crack in my manifold that i somewhat patched. but thanks for the info, when i swap manifolds, ill clean the sensors and get rid of the carbon build up.
"The only way to learn about a car truly is to break something and fix it yourself..."
Threads Similar to: idle
idle Black Five 0h 5.0 Mustangs 12 February 23rd, 2008 03:37 AM
t5 idle terribleonexx88 5.0 Mustangs 5 January 2nd, 2008 01:29 AM
idle help? bone_crusher V6 Mustangs 5 August 18th, 2007 03:59 PM
Idle terribleonexx88 5.0 Mustangs 10 November 14th, 2006 04:08 AM
Idle Problems Code 1506, Idle Overspeed Error jagstang96 96-98 3 August 29th, 2006 05:11 AM
