LinkBack (12) | Thread Tools |
#1
1997 SVT COBRA
1996 Mustang V6
![]() ![]() ![]() ![]() ![]() ![]() iTrader: 14 reviews
Truth about NPI Vs. Pi
Alot of people have gotten on the bandwagon by thinking you need PI heads with the PI cams and PI intake. You don't and there are some running 12.3's on NA NPI headed motors.
For the owners of the 1996 – 1998 Ford 4.6L 2V Mustang GT, the PI (Power Improvement) swap can provide an excellent power boost for these underpowered motors. The PI swap may consist of a complete head and intake swap for full power benefits or just a PI cam and intake swap for decent power gains and other considerations. The pros and cons of both are discussed below. Note: 1996 – 1998 Mustang GT’s are non power improved (nPI) equipped cars. 1999 – 2004 Mustang GT’s are power improvement (PI) equipped cars. The PI cam and intake swap also provides decent power gains absent the draw backs associated with the PI head and intake swap. Swapping PI cams and a PI intake on nPI Stangs results in a 30 – 35 RWHP gain. The cams alone result in a 13 – 16 RWHP gain and the intake results in a 15 -18 RWHP gain. The extra 10-15 on the PI head is the bump in compression with an added cost for the heads. The benefits of this swap are lower costs, less labor, and the fact that you maintain stock compression ratios. PI cams can be purchased used from many parts forums (such as those found on Corral, Modular Depot, or Mustang World) for about $100. PI intakes can be purchased for $100 - $200 depending on condition and whether or not they have the aluminum cross-over (recommended). The install kit with all the gaskets, heater tube etc, is about another $50 - $60. Therefore, for about $300 or less you can obtain up to an extra 35 RWHP making this mod an excellent dollar for horsepower gain! In addition you can use the saved money to port the NPI heads that will have more hp than if you went the PI head route. Some of the common rebuttles is "well i will prot the PI heads then". However, the drawback is that you have introduced much more airflow that the Pi cams, which are oem btw, can't be used to their full potential resulting in no real gain, but possibly a loss of hp. Too much airflow for the cam setup isn't going to yield hp. When swapping PI cams, I recommend that you purchase 2001 + cams. These cams are Romeo cams (manufactured in the Romeo plant) and they have bolt on sprockets. Since the sprockets can be unbolted, you can use the Anderson tool to swap the cams. This makes the job a snap since all you have to do is take off the valve covers, cam covers, use the tool to hold the timing chain in place and then swap cams. Conversely, to do the entire PI head swap, you will have to either pull the entire motor, or tear it down in place to remove the heads. The PI intake is a considerable improvement over the nPI intake. With its increased port volume and improved runner design, this intake has been shown to give up to 18 RWHP increases to the nPI equipped Stang. When swapping the PI intake on nPI heads, make sure you purchase nPI gaskets since these gaskets seal the water ports. Failure to seal the water ports can result in coolant leaking into the combustion chamber and subsequent engine failure, so be sure to use nPI gaskets. Although these gaskets effectively seal the water ports (a must), they do not completely seal the intake ports. You must use high temp silicone sealant (permatex) to seal these ports. AGAIN… only apply the permatex to the intake. Applying excessive amounts of sealant can cause it to ooze into the intake port and obstruct it resulting in hesitation and reduced power. I hope this helps any future 96-98 GT owners that you do not need a PI head to make power with these cars. Johnny Langton pioneered the first PI cam and intake swap and his 4.6 2v NPI motor runs 12.3 so he is proof this can be done and on a budget.
![]() -04 IRS - Magnaflow - Wheel Replica - Autometer - FTBR - FRPP - SCT - Brembo - PRO 5.0 - BOI- |
1998 GT VERT 5 SPEED
![]() iTrader: 1 reviews
good info 4.6, I bought the pi heads, they are getting ported, plus im getting custom cams. oh and the pi intake. They should sticky this post. Good work once again!
![]() http://www.cardomain.com/ride/3068325 EAT ...... SLEEP .......LIFT........repeat! |
Proud American
looks like copy and paste,
but if not good work.
1998 Mustang GT
Need to hit the track!
nice
[SIGPIC][/SIGPIC] Flowmaster MAC Prochamber PI swap JLT CAI BBK 70mm T/B Coming Soon --- Ford Racing 4.10s, SCT XCAL3 |
Wow, I have been saying the same thing for years now. BTW I read that om MD a while back, there is a ton of truth to it. Most cirumstances the heads are only worth 10 rwhp, with a good set of cams up to 25.
nice copy n paste
silver 98gt, blown- sold laser red 98gt, stock- gave away stormy blue 09 mazda3-traded 09 subaru wrx- soon to be 12 sec. daily driver ![]() 1988 gt- toy
1997 CONVERTIBLE GT
UNKNOWN
goota give it up to 4point6 for even posting this i think it was a good idea even if all these guys are saying its a copy and paste at least you posted it they should sticky this
wanted to know how could you guys tell that its a copy and paste?? |
The Hammer
Millenium Falcon
who was saying that u needed PI heads in the first place?
Some good information here......
It may have come from somewhere else but i dont think its a direct copy and paste. But alot of people know that you can make a NPI mustang quick. Its just much easier to do it with PI parts as its been done much more. But, good information none the less.
1996 Mustang GT, Full PI Swap, MGW Shifter, Magnaflow Cat-back, K&N Filter MM Unite For Bubba |
Far too intelligent sounding to come from him
![]() Jk ![]() PI heads ftmfw i dun care what you say =P |
MM's DRUNKEN SAILOR
good info ive thought the same too its also better for FI with the lower compression aint it
![]() MILITARY CREW GSM3 i love throbbing meat
98 Mustang GT
11.9 @ 119
copy and paste!!!!!
thats from SN95 forums!!!! LOL the 96 to 98 tech thread! At least say you got it from some where else and give the credit to the person that posted it!! Truth about NPI vs PI
u piss me off and that was a copy and paste. fail/
48.47@ 12.58
who cares if it's a copy and paste.
one of my stickies is a copy and paste. it's good info and take it as that
i know. ive read it already and im a believer that you dont need PI heads...the few shops ive talked to told me they dont port npi's though...
Yes, regardless, it is great information for anyone whose NPI
![]() Cammed 2v Built By MustangMatt More mods than times your daughter has slept around |
.000000000000001
If It was not for him copying and pasting i would have prbably never read this.
I got that vtech |
#18 | |
1997 SVT COBRA
1996 Mustang V6
I was not trying to steal it and diddent think it would matter i figured some of you have all ready read or seen it or are members of Sn95 forums.. i jsut thought it was a good wright up and wanted to share it with you guys .. sorry i did not state in the begining that it was not me i did not even think about it ...
1997 CONVERTIBLE GT
UNKNOWN
its cool lol some people on here enjoy putting people on blast
#20 | |
Threads Similar to: Truth about NPI Vs. Pi
| Truth about Trucks | Regency 2007 | The Clubhouse | 0 | March 21st, 2008 09:10 AM |
| The moment of truth! 2/25 | itschristorres8 | The Clubhouse | 18 | February 25th, 2008 11:40 PM |
| moment of truth | thetrooper31 | The Clubhouse | 0 | February 25th, 2008 08:05 PM |
| Truth about stock block | j2000_guy | 94-95 | 9 | May 3rd, 2007 08:07 PM |
| Okay So The Truth About Superchargers Comes Out | NottyBoy93 | General Tech | 22 | April 8th, 2007 11:58 PM |
