quick shifts
I just had a new clutch put in my 96 gt back in march.....ever since then i have had trouble shifting when i race....it doesnt like to be shifted quickly...is that because it is a new clutch and needs to be broke in or am i doing something wrong
New Clutches do need to be broken in, for about 300 miles i believe. And if you upgraded from a stock clutch to an aftermarket one, the new one is probably stiffer. Make sure you are getting it all the way to the floor before shifting, other wise it can make it difficult.
![]() Cammed 2v Built By MustangMatt More mods than times your daughter has slept around |
Proud American
ts probably not adjusted correctly.
Threads Similar to: quick shifts
| 92 AOD tranny shifts to fast | 92sspnotchback | 5.0 Mustangs | 5 | November 11th, 2007 06:36 PM |
| Silly ricer shifts 3rd to 2nd | vnmous | Videos | 10 | June 30th, 2007 10:27 PM |
| Cold Shifts | Garhfer | 99-04 | 13 | April 4th, 2007 05:06 PM |
| Do you experience hard 1-2 shifts with your 3650? | acmillr | 99-04 | 7 | March 12th, 2007 12:41 PM |
| Engine RPM steady between shifts | cobralini | 5.0 Mustangs | 6 | July 22nd, 2006 12:41 AM |
