Possible clutch problem? Please help!!
Ok.. This tends to be more noticeable at start up/warm up. At idle, there is an extremely annoying noise coming from what seems to be toward the rear of the motor. Kind of hard to explain the noise.. not so much of a grinding, but more of a metal-on-metal friction noise (if that makes a lick of sense!)
Here's the thing, when I push in the clutch the noise dies down or stops completely. But as soon as i let off.. there it is again! What could it be? Flywheel? Pressure plate? This sucks! It's summer... I like to put the top down and just cruise, and of course turn a few heads occasionally.. but not because of an annoying sound! Any suggestions? I'm pretty busy, so I haven't really had any time to have it checked out. Thanks everybody! |
2002 MUSTANG GT
14.2@100
![]() iTrader: 1 reviews
i have an 02 and have the same noise! mine doesnt do it all the time only sometimes! i would be curious to hear someone chime in on this!
If the noise changes when you puch the clutch in it could be the pilot bearing... Mine was squealing real bad until I recently replaced the whole clutch assembly and all
![]() 2004 Comp Orange GT - SLP Loudmouth, Pypes O/R X Pipe w/mils, Steeda Tri-ax, JLT Ram Air |
Sounds like a pilot bearing to me. When you push on the clutch it transfers the load from the pilot bearing to the release bearing/input shaft and the noise will change. When you let go the load returns to the bearing and so does the noise.
Beware if this bearing is noisy it is only a matter of time before it blows apart and can cause input shaft damage which costs more money. Do the clutch disc, pressure plate,release bearing and pilot bearing (clutch kit) at this time. Also check flywheel surface for cracks/hotspots/scoring and have either resurfaced or replaced depending on scope of damage. hope this helps |
Threads Similar to: Possible clutch problem? Please help!!
| clutch problem? | blue03mach1 | 99-04 | 30 | January 18th, 2008 05:04 PM |
| Clutch Problem? HELP | EasyE64 | V6 Mustangs | 40 | November 27th, 2007 08:45 PM |
| clutch problem | rob madison | 96-98 | 5 | October 26th, 2007 10:06 AM |
| problem with clutch. | mike96gt | 96-98 | 2 | September 21st, 2007 03:33 PM |
| clutch problem | rottikk | 5.0 Mustangs | 6 | November 28th, 2006 09:03 PM |
