#21 |
I will just note that the complete removal of the swril damn it a big NO NO. Not knocking anyones work, I am not a god. The intake runners on your heads appear to be way to smooth, smoothing of the intake runner actually will cause turbulance in the runner. A rough surface actually creates a cushion for the passing fuel air to better atomize and increase velocity to push through the shortside radius.
Recently i found a minor angle cut on the swirl damn will increase the overall cfm numbers. I have been able to mirror most companies heads with larger valves by using stock sizes. I found on several heads I have tested that most porters are removing way to much material in the port cross sectional areas. You are going to have to try them out, they may be a little lazy on the low end but should pick up in the mid to upper prm's. The work appears to be average, not saying bad as I can't see pictures of the runners. Good luck and I will be happy to answer any questions you may have.
#22 |
Here are a few pictures of some of the heads I did in the past. Changes have been since made so no spy photo's LOL
#23 |
1998 GT VERT 5 SPEED
![]() iTrader: 1 reviews
thanks for your input boomer. I stated earlier that ac has not finished the heads yet. Those pics were in the process. He hasnt cleaned them or anything. I just wanted some pics so i could post some in the process of being worked. I wll post some when he completes them fully also.
![]() http://www.cardomain.com/ride/3068325 EAT ...... SLEEP .......LIFT........repeat! |
#24 |
Proud American
make sure you have permission from AC to do so. He has put work into them and may not want it shared. Just like he was watching out for boomer....
#25 |
good to go. already ran it buy him.
#26 |
throw those heads in my steamer transmission washing machine and they will come out brand new..ive done it on a couple 4cyl heads already..
#27 |
i would if i were closer. My wifes family is from pascagoula ms, i was stationed there for 3 years. small world huh
#28 | |
MM's Mad Scientist
Slow Fella
![]() ![]() ![]() ![]() ![]() ![]() iTrader: 2 reviews
#29 |
Proud American
its too bad on the built engine I am going more agressive and going to try and sell these heads as long as nothing was damaged from
no oil pressure for a few minutes.
#30 |
95% of all the porters now barely touch the dams, it kills low level lift numbers like a bitch. Unless you plan to squeeze a .700 " lift cam in there it is not worth the loss. Think about the duration the cam spends at max lift compared to low to mid, point made.
Again as Ac said everyone has their own way to do things, I am just providing a different view.
