NPI or PI motor?
Old November 1st, 2006, 11:54 PM   #1
Blue98GT is on a distinguished road
NPI or PI motor?
Ok so easy question for you all... which do u think would be the best way to go with my 98 GT... go ahead and do a PI motor swap or jus swap the PI Intake, cams and such into my NPI motor? if u think the PI motor swap are there any big issues when it comes to the swap and do u think my local ford dealership might do the swap for me? I would really like to achieve at least 300 hp with my mustang... the bolt ons i would include for now would be bbk Long tube headers and O/R x pipe with CIA and 75mm TB and 3.73 gears. OH and BTW does anyone know of a good mustang tuner shop around the Kansas City area? thankx, john.
Old November 7th, 2006, 10:18 AM   #2
mm's nitrous mod
SWEET2KSTANG's Avatar
2000 mustang gt
11.79@115.83 (old set up)
iTrader: 8 reviews
to acheive 300 rwhp on a non-pi 2v car will be tough with just the average bolt-ons, all though it is very possible with the right stuff. it would be a lot more efficient from idle to redline with a pi set-up. i am close to that mark with what i have and almost every power bolt-on external is done. the dealership will more than likely only do a stock motor swap.
Old November 9th, 2006, 11:45 AM   #3
1998 mustang gt vert
98stanger is on a distinguished road
Send a message via AIM to 98stanger Send a message via Yahoo to 98stanger
long tube headers and a x pipe on a mustang would produce around 25 or so more horses and on the pi motors even more is possable
Old November 10th, 2006, 12:32 AM   #4
Green Hornet's Avatar
Green Hornet is on a distinguished road
if you are going to add a power adder like a supercharger sometime, get the PI motor. if you do the PI head swap, it will raise your compression. if you arnt going to put a superchatger on, go for the PI heads and intake. there wont be any probs with putting in the Pi motor. you will have to tap ito the intake for your 2nd temp sensor either way.
SPECIAL THANKS TO:
www.afterburninc.com
www.dynotunemp.com
http://www.per-race-engines.com
[/COLOR][/URL]
Old November 10th, 2006, 05:51 AM   #5
RLY SRS
ChrisJ's Avatar
iTrader: 10 reviews
If you are going to be adding a supercharger on the stock bottom end then DO NOT DO THE PI...It raises your compression ratio...
You can have you stock heads ported and polished to outflow the PI heads and get yourself a set of cams and go at it...You wnat low compression ratios for supercharged engine...
A NPI with ported and polished NPI heads and a nice cam can see 300rwhp with botl-ons pretty easily...
The killer of the NPI's is that the heads dont flow worth a $hit...You fix that and you are all good...
Now if you plan on staying Naturally Aspirated or Nitrous then do the PI swap...
Facebook
Google+
Old November 10th, 2006, 08:35 AM   #6
bigmike83's Avatar
1997 mustang gt
8.06 at 87mph 1/8th mile on a 50 shot
bigmike83 is on a distinguished road
Send a message via Yahoo to bigmike83
go with pi, my car factory put 185 to the wheels then with all bolt ons but cams and pulleys it put down 215 and it is a stick car too, go with pi best think i did, but once you start there is no turning back cause now i'm looking for MORE POWER
97 gt with
2004 pi motor,acufab intake and 75 mm
bbk cold air kit,bbk long tube headers,
off road h pipe,2 chamber flow,
3:73, diablo chip with dyno tune
269rwhp 301rwtq
5.4 SOHC FOR SALE
pm me for details
Threads Similar to: NPI or PI motor?
need some help american motor to import motor wadepetersen V6 Mustangs 29 May 30th, 2007 09:26 AM
V8 motor wannabeimportkiller 5.0 Mustangs 2 May 29th, 2007 05:51 AM
How do you find the motor code on a 88 5.0L motor? semihemi428 5.0 Mustangs 1 March 16th, 2007 04:56 PM
Best Motor Oil Vendetta V6 Mustangs 22 December 17th, 2006 04:43 PM
