LinkBack (4) | Thread Tools |
#1
Screamin Demon Ignition System Installation
Alright I haven't seen one of these around the boards so here we go. its a VERY easy swap.
You need to order the Screamin Demon Coil Packs, Livewires, and the Billet Wire Looms are optional. Everything should come up to about $300 or on the lower side of that. Also its a REALLY GOOD IDEA TO GO PICK UP SOME NGK TR55's from Advanced Auto Parts or some SINGLE PRONG PLUGS. I refuse to use anything else but NGK 1.49 a plug FTMFW. Tools: 3/8 Ratchet, 3/8 6" Extension, 10MM shallow socket, 5/8 Plug Socket, 1/4" Ratchet, 3" 1/4" Extension, 7MM 1/4" Socket, Flat Head screwdriver, Dielectric Grease, about an hour of time. Here's what were working with.... ![]() ![]() -To start off, remove the strut tower brace (if present) using the 3/8 ratchet and 10MM socket. There should be 8 10MM bolts holding it in there and then it just pulls right off. -Next remove the intake tube from the throttle body to the MAF and the flex joint (if you have an aftermarket intake tube). Unplug the IAT from the intake tube and remove the tube itself. And the tube going to the upper plenum and the PCV hose on both sides. -Now unplug the coil packs and remove them using the 7MM socket and the 1/4" Ratchet. Keep the ground connectors on the bolt and when you install the SD coil packs put them in the same place. DO NOT REMOVE THE WIRES FROM THE OLD COIL PACKS OR THE PLUGS. Here's what you should have in front of you.... ![]() -Ok Now plugs the new CP's up and transfer the wires over. from the old CP's. Throw the old CP's in the garbage, they suck anyway. -Start tracing the wires to the plugs and remove them ONE AT A TIME!!!!!!!! Pull the boot off the plug and use the 5/8's plug socket and 3/8 ratchet and 6" extension to remove the plug. Hopefully you bought some NGK TR55's and you need to go now and gap all of them to .065, It's a big gap but this system is HOTTT. Alright put the plug back into the hole it came from and find the matching wire numbered 1. Hopefully thats where you started from. First cylinder on the passenger side. Repeat this process seven more times and your done!!!! -Put your intake tube and back in there and all the PCV hoses and such. Finally put the strut tower brace on using the 10 MM bolts you took out. Pay close attention to the back two bolts as they are smaller than the other ones that go to the strut tower. Yup, thats me hard at work on my old baby. ![]() I miss these days on the old 97...... ![]() Now your all ready to start her up and take her for a run. Heres what you should have... ![]() ![]() ![]() Ok guys, Thanks for checking out my write-up and I really hope yall look into this mod. The car this was done on was my old 97 GT with a Full PI Swap, Sniper Tune, 3:73 gears, MGW Shifter, Accufab TB and Upper Plenum, King Cobra Clutch, Cobra Transmission, BBK CAI, BBK Catted X-Pipe, Magnapacks, and some other stuff I can remember. The car felt like something was holding it back after the swap and it couldn't even chirp the tires in second, well after this my buddy took it out and spun in 1st, spun 2nd, and had a pretty long chirp, or squeal in 3rd. The spark up top is amazing being that the 4.6's stock ignition system has a drop off up top, this system makes the car pull harder than ever. Look into it guys, its well worth the money. Let me know if yall got any questions.
![]() EAGLE SCOUTS OR GTFO MyStangOpens (12:01:05 AM): honey nut for me Last edited by 68 dlxcoupe; May 29th, 2008 at 07:18 PM. |
very nice job. Reps given
Thanks HMUSN can we make this a sticky??
![]() EAGLE SCOUTS OR GTFO MyStangOpens (12:01:05 AM): honey nut for me |
ask a mod.
Smelly Fists, Socking Cocks
Millenium Falcon
nice write up
and LOL at the irony above me |
Nice write up, maybe the coil packs will make enough power to offset that BBK hot air induction.... Sorry, I could not resist. I tested those against the stock, accel and msd. I was actually suprised how well they worked, I can say if it was them alone as I was running a MSD dis4 but they actuall made 5 rwhp over the rest.
My friend has been running them for over a year now on his big turbo Bigbore with no issues. The accel lasted 2 weeks and the msd never went bad just seemed to get weaker with time.
Millenium Falcon
Biker MIce From Mars!
holy shit man |
HAHA I lived off that show on elementary
Def. Needs to be a sticky. Great post man
![]() Cammed 2v Built By MustangMatt More mods than times your daughter has slept around |
1998 Mustang Coupe
Amazing
![]() ![]() iTrader: 2 reviews
nice post man. I think i will give this a try whenever i can get the money for the coils
reps |
1997 SVT Cobra
Great post, it is nice to see pics with it, I will look into this for the Cobra. Thanks
1996 mustang GT
Way old post lol
MM's Samsquanch
1998 GT
it may be old but its a good write-up and its good to see someone new searching for info.
MILITARY CREW
USMC E-4 |
1997 Pacific Green Cobra
14.9 No traction
yeah i went ahead and put some in with sep colder motorcraft plugs. these really did make a diff.
GT ENGINE (temporary) 4.30 Gears , 31 spline Moser axles , Detroit tru Trac diff, Jmod 4r70w , Pi intake/ cam swap . Aluminum drive shaft. Lowering kit x2 ball joints ,screamin demon, LCA "Bolt ons "
1997 SVT Cobra
good evening, i purchased the coil packs and live wires, there is about a two inch difference in length on the boots, from the ford racing ones i have now. 97 svt cobra, any rec. thanks for your time.
terry |
biker mice from mars!!!!!
It sounds like you bought wires for a 2V. You need 4V wires for your Cobra.
Rod @ AzzKicker Cars 2004 Ford Mustang GT-The Driver-BBK CAI, PP TB & Inlet, Steeda UD's, SLP LM1, & 3.73's. ![]() 1990 Mercury Cougar XR7-The Meth Addict-5.0L DOHC Stroker w/2.1L KB SC. ![]() 1995 Ford F150-Mud Toy-5.0L, 4x4, 33's, & Warn 8274 Winch |
LinkBack to this Thread: http://www.moddedmustangs.com/forums/96-98/73366-screamin-demon-ignition-system-installation.html
| screamin demons - MustangForums.com | This thread | Refback | February 1st, 2010 07:18 PM | |
| screamin demons - MustangForums.com | This thread | Refback | December 9th, 2009 04:37 PM | |
| screamin demons - MustangForums.com | This thread | Refback | June 3rd, 2009 04:42 PM | |
| Screamin Demon Ignition System Installation | This thread | Refback | May 30th, 2008 08:45 AM | |
Threads Similar to: Screamin Demon Ignition System Installation
| screamin demon coil pack for 01 | dgt_mustang | V6 Mustangs | 17 | June 5th, 2010 05:47 PM |
| MSD or Screamin demon | whtstang97 | 96-98 | 3 | April 27th, 2008 10:38 PM |
| Screamin' Demon Coil | blazor | V6 Mustangs | 10 | August 12th, 2007 09:48 PM |
| Screamin Demon VS MSD | 00RoushV6 | V6 Mustangs | 2 | February 22nd, 2007 08:18 PM |
| Screamin Demon | 2000Mustang | V6 Mustangs | 4 | January 30th, 2007 08:52 PM |
