LinkBack (1) | Thread Tools |
#1
the fucks i gave today=0
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 0 reviews
alternator or something else?
so im wondering if my problem is the alt or something else my car has a horrible habbit of wanting to die once in a while becoming more and more prevelent. this doesnt happen slowly it only happens when im sitting idle at a light or something it looks like someone just cut the battery cable and put it back the vol gauge drops off car almost dies and it comes back to normal. im thinking if it was the alternator it would slowly die over time not just out of nowhere volts drop off car almost die and comes back. this happens most of the time while the a/c is on and even more so in situations like today when it was raining and hot so the headlights a/c wipers and radio was on.
Load test the battery.
Have the alternator tested. Check the connections at the battery, the alternator, and the starter. To me, this sounds like a shitty connection at the starter. Make sure you disconnect the positive terminal at the battery before messing with the starter connections, as a wrench jammed between a power cable on the starter and the frame or engine block is a very bad thing. |
05 MustangGT 422whp417rwt
12.5@109
![]() iTrader: 4 reviews
Autozone can check those For you. Maybe a possible intermitten short.
M90 Roush with 2.49 pulley,Flowmasters axel back,Deep Dish Bullitt Wheel (18x9)Front (18x10), BFG KDWII tires,3.73 gears, BMR LCA, Roush Front bumper with chin spoiler, Cervini M1 hood scoop, power slot rotors, SLP line lock
cool ill run to autozone this weekend i know the battery is less then a year old i had to put a new one in when the old one kicked the bucket. on a side note the fucking car dies everytime i put it in neutral that aint right
12.5@109
When it does idle is it rough? not sure if they have a check for it but maybe an EGR valve? Not sure about that but worth checking.
Also consider checking the IAC unit. It may need cleaing or replacing.
it only idles rough when i am sitting at a stoplight with the car in gear breaks on and mainly when the a/c is running or multiple electrical components like lights wippers radio at the same time like today and i used to be able to kick it in neutral and it would stop well now when i do it dies
12.5@109
Well I think you have a starting point for somthings to check. Also make sure the battery terminals do not have a lot of corrosion on them.
12.5@109
Dennis did you get this checked out yet?
LinkBack to this Thread: http://www.moddedmustangs.com/forums/96-98/75064-alternator-something-else.html
| alternator or something else? | This thread | Refback | June 12th, 2008 11:07 AM | |
Threads Similar to: alternator or something else?
| Alternator | JStang14 | 94-95 | 2 | February 9th, 2008 08:56 PM |
| alternator | WilltheThrill | 4V / SVT | 5 | February 2nd, 2008 08:28 PM |
| Alternator | bluemustang04 | 99-04 | 20 | December 26th, 2007 08:26 PM |
| New Alternator | Thewolfman456 | 99-04 | 2 | May 8th, 2007 07:31 PM |
| alternator | 89mustanggt | 5.0 Mustangs | 5 | May 19th, 2006 08:43 AM |
