Genibus Nitito Canus
What about this?
I was looking thru the jegs catalog today and came across Granatelli Tubular Front End Conversion Kits - JEGS. Is it a good deal? do is Granatelli a good brand? Is there anything else I would need to put this on my car? Even tho its a coilover conversion, can I still use a McPherson Strut set-up? I would like to be able to use the Air-ride's Ford Mustang 93-04 -Street Challenge Kit-: Air Ride Technologies - Ridetech.com some time down the road. Thanx
Red 1996 GT: JLT RAI, Steeda Underdrive pullies, Stewart Waterpump; nothing to brag about Black 2009 45th aniverary edition GT 5 speed: K&N CAI, BBK Twin 62mm Throttle Body, BBK Underdrive Pullies, SLP Loudmouth ![]() |
bump
Most Mustang guys that are serious about suspension stuff wouldn't touch Granatelli stuff with a 10-foot pole. Generally, it's said that they just make low-quality copies of other people's legitimately engineered parts.
1993 2.3L Coupe [Motortopia] : Open-Track Project... 216k miles 2000 V6 (Black,5-speed) [Motortopia] : Heads/Cam (EXHAUST CLIP) 2001 Harley Davidson F-150 Acts 16:31 |
ok, i kinda figured what might be the case for the price
Yeah, *usually* you get what you pay for, but it's worth asking.
Personally, I'll likely be going with Maximum Motorsports. That's a lot more money, though.
ya thats what i was looking at be4 i came across the Granatelli.
mm's nitrous mod
2000 mustang gt
11.79@115.83 (old set up)
nothing wrong with gms product. i run them and have no issues at all. i have only had one item that came up with an issue, gms stood behind it 100% and fixed it. i personally have ran their products for a long while now, i have no regrets or complaints. i am thinking of selling my qa1 for the gms set up. most idiots on here just dont get it, does everyone on this board think every company make their own products??? gms makes products for other companies. gms supplies products for other companies that use their own label, most guys have their products and dont even know it.
![]() project warhorse under construction wagon burner under construction as well (04 lightning) being built by MP2 Performance Last edited by SWEET2KSTANG; June 12th, 2008 at 03:36 PM. |
Really? got any examples?
mm's nitrous mod
2000 mustang gt
i do, but that will cause nothing but more arguements. i will see who all they make products for, but that may take a little bit.
well i got nothing but time. if Doc trusts u enough to let u work on his mach, then i think i can trust ur advise on suspensions
mm's nitrous mod
2000 mustang gt
each person will have their own opinion on every product, thats fully respectable. i have worked on a lot of cars, built a lot of cars, etc. i wont use something that i wont trust on my own car. depening on what exactly you want to do on your car can affect what kind of parts you need to purchase. i will have to do some research to see if there will be any issues with the air ride set up on it, i havent heard or seen anyone run a set up like that before.
well the reason im interested in air ride is for the ability to change my ride hieght on the fly. if i dont go air ride, im gonna go blistien (sp) and im sure the gms system will work with bilstien
#13 | |
![]() iTrader: 1 reviews
Our product has a customer satisfaction promise so that should always put to rest the worry that if it does not work you may be stuck – not with our product. Our parts will not work with the air ride struts though so if you plan to go that route we can’t help you. However you said you wanted adjustability for height. Our coil overs allow for a 2.25 drop or a 1” lift from stock. As for the latest BS about off shore copying, I think it is safe to say GMS has been copied as much or more as any other product out there. I love how a few guys claim that because we offer the parts at killer prices it must not be a good part. That is ridiculous. That is like saying the higher the price of a car the faster it will be or the better the quality. – NOT TRUE |
Ive heard nothin but good stuff about Granatelli. I wanna get those coil packs from them for my cobra. I had no idea their tubular front ends were that price, Ill definetly get that setup when the time comes.
Black 2001 SVT Cobra Solid axle "Good judgment comes from experience, experience comes from bad jugment" MM Cobra Club Member #1 |
#15 | |
MM Aluminum Steering Rack Bushings MM Caster/Camber plates MM Adjustable Tie-Rod Ends MM 2-Point K-Member Brace Urethane front swaybar bushings Swaybar end links (shorter) MM Front Swaybar Relocation Kit how vital are those extra parts?
#16 | |
Alum off set rack bushings and a 2 removable 2 point lower support brace for the K-member at no extra charge We offer offer 3 bolt or 4 bolts caster/camber plates and Bump Steer kits (tie rod ends) at an extra charge |
what material are ur bushings?
rack bushings are 6061 alum
A-arm bushing are Energy Susp poly or for $70.00 more we offer delrin |
ok
2001 svt cobra
12.84@110
i love it when the company or a rep. can get on a forum and set the record straight and give potential customers the confidence to buy their product. and also give other companies and products the respect they deserve while still promoting their product. GMS you have just earned a lot of respect from me. well played.
![]() tri-ax, alum. drive shaft,caster/camber plates,cia, SCT chip,4.10 gears,solid axle swap, 31 spline axles,UPR control arms, UPR A-arms, flowmasters,MSD 2-step,SLP line lock,front and rear coil overs 307rwhp,309rwtq MM New Edge Cobra Club Member #4 |
