Discussing Throttle body question in the 96-98 Forum. Correction on the 90mm MAF. It is the MAF sensor I was thinking of, my ...
Old June 25th, 2008, 05:24 PM   #21
1997 Mustang GT
Correction on the 90mm MAF. It is the MAF sensor I was thinking of, my bad. However, the point is this. The corba, a factory supercharged engine comes with an oval TB that flows as much or more than a 75mm TB. And if you plan on getting FI, you should buy the best TB for your Set up. If you are getting some crap Supercharger kit that gets you a total of 360 hp, your 75mm TB will be fine cause your car isn't doing much. If you get a kit putting out 430-500, you will definitely feel the difference in a 75mm and a dual 65 or Big Oval TB.
Old June 28th, 2008, 02:42 PM   #22
97S281's Avatar
1997 Saleen S281
the only aftermarket setup to show worth while gains is the accufab tb AND plenum. This is from sean hyland motorsports. they have been building mod engines since they have been making them and have written several books on how to build maximum performance for the 4.6 and 5.4 engines. they show dynographs for different tb setups and accufab was the only one to gain any hp, and honestly that is still pretty minimal at 10 hp on a stock gt. it's not really worth the 350 bucks for the setup unless you plan on some significant mods to go with it.
hmmmmmmmmmmmmmm.....
Threads Similar to: Throttle body question
Throttle Body Question 95blackbeauty 94-95 2 September 17th, 2007 10:55 PM
New Throttle Body question neckbonekat 99-04 3 July 15th, 2007 09:42 PM
Throttle Body Question sbland26 V6 Mustangs 44 May 20th, 2007 03:26 AM
throttle body question RyanGT 99-04 32 January 8th, 2007 10:05 PM
Question About Throttle Body BiGD12590 99-04 14 July 30th, 2006 09:47 PM
