94 GT
stock specs?
hi, might be sellin my fox and getting a 96-98 mustang. but i need some specs for a stocker.
2 or 4 valve? hp/torque number? weight? gears size? quarter mile time? good price range to look for?
94 GT - Deep Forest Green Off road X, flowmaster single chambers, typhoon intake, hurst short throw, CAI, eibach sportlines, 315s, foxbody short block ![]() |
Proud American
215 HP
3400 pounds, gears could be: 2.73s 3.08s 3.27s quater mile time: low to mid 15s Basically very slow and expensive to mod... i would pay around 4K-5K for a decent one here in CO
94 GT
is that low to mid 15's here in colorado or sea level?
Proud American
sealevel...
first pass in my relativly stock car was a 16.7 at bandimere... i had CAI, UDP, shifter, Nitto 555s, O/R H pipe, and Flowbastereds... But thats at bandimere. Peublo where you run it would prolbably be around a high 15 low 16
94 GT
no gears?
Proud American
i had 2.73s
94 GT
thats actually not bad for 2.73's my 5.0 with a verry little done to it ran 15.1 and im inexperienced so id guess with 3.73's (is that what these cars like? or 4.10) it would easily take near a second off that time
true you had slicks but you cant really launch off of 2.73's
Proud American
well i didnt have slicks at the time...
now the car has a whole top end pushing over 300 HP, slicks and skinnies, drag springs in the rear, and a hit of 100 HP. I never ran the spray in the motor before i spun a bearing, but on motor, untuned, i had the car doing 14.2s@98 MPH. It was lifting the front drivers side tire occasionally about an inch in the air.
94 GT
so if i can either find a car with gears or buy gears for one, it will probly run low 15s if not a 15 flat mostly stock right?
Smelly Fists, Socking Cocks
Millenium Falcon
pretty much unless u drive like cams-shelby
94 GT
that doesnt sound like a bad deal, i may just be going with a one of these here in the future
Proud American
i would say more closer to mid 15s
94 GT
still thats not too bad, with some springs a little weight drop, some small improvements on exhause and a good tune (plugs and wt not), CAI ill bet i could get it in 14.8 14.9 with slicks more like 14.6 14.5
are these cars OBD1 or 2?
Proud American
OBD 2 cars, but 14.5 is not possible with out a set of heads and cams, or nitrous or a blower. Even when i had the slicks with 4.10s i was only pulling 2.0 60's because i didnt have the power to get it to launch. It would run 15.3s like that.
Tuned my car should have done a 13.9 and on spray around a 12.5
Millenium Falcon
2
he's not at seal level is he matt? if he's not i take back my previous post and u'll still be in the 15's |
Proud American
he is in colorado...
but peablo the track near him is 3800 feet IIRC and that track is prepped like poop
94 GT
what kind of tourqe numbers do these put down?
Proud American
stock i dont have a clue....
but i dynoed mine with a PI intake and made 192 HP and 230 TQ on an awd dyno
Millenium Falcon
3800ft is still good for a half second cock block.....
Proud American
not on that track it aint...
turns out the track is a road course. and on one of the straight aways, thats the 1/4 strip... you get the picture.
Threads Similar to: stock specs?
| stock specs 5.0 | RIDIN5.0 | 5.0 Mustangs | 13 | May 22nd, 2008 11:11 AM |
| info regarding stock engine specs(cams, c/r, etc.) | prodrifterx | Modular Mustangs | 4 | February 24th, 2008 09:59 AM |
| Stock Specs 89 LX 5.0? | teal89 | 5.0 Mustangs | 9 | February 21st, 2008 02:58 AM |
| Stock engine specs | hubba076 | 99-04 | 2 | August 17th, 2007 06:36 PM |
| Stock speaker specs | cobralini | Audio/Video | 6 | August 25th, 2006 11:48 PM |
